Old 11-08-2013, 02:18 AM   #1
Drewski23
Is an 8" dual diaphragm booster enough for my application?
Hey guys, I'm converting to discs up front and need a brake booster. I like the look of the smaller 8 inch boosters but i'm concerned about the amount of pressure they can produce.
Eventually i may use the truck to pull a small open trailer with my mustang on it to the autocross track..I have no experience towing so i dont know what the braking situation is like.
Regardless if i use it for towing or not, If i eventually go to discs in the rear would that affect the performance of the brake booster?
Drewski23 is offline   Reply With Quote
Old 11-08-2013, 08:17 AM   #2
Sammy
Re: Is an 8" dual diaphragm booster enough for my application?
Amount of vacuum available from your engine is the answer to your question. The more radical your cam less vacuum it produces. In most typical stock engine applications a 8" booster is fine.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-08-2013, 12:01 PM   #3
mgchevyparts
mgchevyparts's Avatar
Only if it's an 8" dual. The 8" dual provides slightly more then the 11" single which was commonly used on trucks.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 11-08-2013, 12:11 PM   #4
Drewski23
and going from disc/drum to disc/disc would make no difference at all in the effectiveness of the booster?
Old 11-08-2013, 05:18 PM   #5
tony58
Your future trailer needs to have electric brakes, no need for rear disc on your truck.
tony58 is offline   Reply With Quote
Old 11-08-2013, 05:53 PM   #6
Fitz
A disc -disc setup works fine on my truck with an 8in dual Diaphragm booster. Plenty of stopping power. If you pull a trailer be sure you have enough tongue weight on the rear to make use of the rear discs. If the rear isn't loaded the rear brakes are ineffective and you might need a trailer brake..
Fitz is offline   Reply With Quote
Old 11-08-2013, 11:53 PM   #7
Drewski23
Interesting..i honestly had no idea that trailers came with electric brakes.
I was thinking the same thing though..when im not towing how much more effective are the rear disc going to be than drums? with there not being any weight back there and all? I just figured discs have to be better than drums for the rear but maybe not much..
