11-08-2013, 12:59 PM | #1 |
Rim inquiry 1963 3/4 ton c20
Hi can any one tell me if these will fit? The lug guide on the forum started at 1965 so I donno my lug pattern so I assumed it at 8x6.5 posting the link of the ones I like. Can I use them on all 4?
http://www.ntwonline.com/16X8-8X6.5-...on-Wheels.html |
11-08-2013, 01:07 PM | #2 |
Re: Rim inquiry 1963 3/4 ton c20
I wont say for sure, but i dont see why they wouldnt. You need to measure your pattern to be sure. I have a 66 c20 and thats the size i have. I am running 88-98 chevy truck 8 lug rims on mine. Bolted right up no probs.
11-08-2013, 01:40 PM | #3 |
What is the back spacing on yours and rim size and did you use the same on all 4?
11-08-2013, 06:58 PM | #4 |
I think its 4.25 bak spac and the size is 16 x 6 or 7 and they are all the same.
11-08-2013, 08:31 PM | #5 |
Are at stock ride height, I run the stock chromed rime off a 93 Silverado.
11-09-2013, 01:06 AM | #6 | |
60-66 Nut
Yes your '63 C20 has the 8 x 6.5" bolt pattern. I don't see why you couldn't run those on all 4 corners.
