Old 11-08-2013, 02:06 PM   #1
Bhelton
Bhelton's Avatar
Lower radiator hose issue
Running mid mount zoops kit and lower hose don't seem to fit right, resting on frame and would rather not replace later on. Any suggestions?
Sbc 350, zoops mid mount drive system, long water pump and champion radiator. Here is a pic
Bhelton is offline   Reply With Quote
Old 11-09-2013, 04:19 AM   #2
JonCheun
Re: Lower radiator hose issue
Could always get a cool flex radiator hoses? you can cut them to length and bend them any way you need to.
I'm replacing my radiator too! Was yours old too? What all did you replace?
I'm only replacing the radiator and overflow tank b/c they were rusty. I'm think the transmission cooler may be rusty too b/c the radiator and overflow were but don't know if I should replace it too.
I'm going to drive on it for a week or two and see if there is still rust in the system if so then I'll replace it.
JonCheun is offline   Reply With Quote
Old 11-09-2013, 09:05 AM   #3
Your radiator looks like it has the neck for the 73-87 style truck. I thought ours had more of an up-turn to clear the frame. You could also put a rubber sleeve around your hose so that it doesn't rub directly against the frame.
Old 11-09-2013, 09:24 AM   #4
Bhelton
Bhelton's Avatar
Thanks guys, I bought a flex hose last night and installed it and everything looks 10 times better. Hoping to fire engine today for the first time
Old 11-09-2013, 10:03 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by palf70step View Post
your radiator looks like it has the neck for the 73-87 style truck. I thought ours had more of an up-turn to clear the frame. You could also put a rubber sleeve around your hose so that it doesn't rub directly against the frame.
x2
WIDESIDE72 is offline   Reply With Quote
Old 11-09-2013, 10:55 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
X2
The lower nipple need to be cut off an a pie shaped wedge taken out. Rhe rewelded to make it point upward. Most boat repair shops have someone on staff that can weld aluminum
