11-08-2013, 07:36 PM | #1 |
HOW TO: Install/ Remove your bed by yourself
Step 1: Jack up the rear of the bed, roll a cherry picker under.
Step 2: Attach straps to the center of the arm, and to each of the four corners. Step 3: Jack away! Step 4: Back the truck under the bed. Step 5: VERY CAREFULLY AND SLOWLY lower the bed while controlling it's position by holding on to the side. YOU'RE DONE! Bolt her on and you're ready to go. Don't forget to put your straps away neatly. Removal is done in reverse order!
1980 c10 Custom Deluxe 296 inline ;] SM-465 and 3.73s Lowered and shaved My Build! |
11-08-2013, 10:10 PM | #2 |
Re: HOW TO: Install/ Remove your bed by yourself
C'mon man your engine hoist is huge
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
11-08-2013, 10:23 PM | #3 |
Cherry Pickers work great
I used some 2" angle and a couple 2x4s to slip under the lip of my 70's fleetside. I came in from the side with mine. Nice job with yours. I never thought about coming from he rear on mine, probably because I had room from the side though. I was nervous about using strap on mine as I thought it would twist the bed sides some, so I came up with the braces.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-08-2013 at 10:52 PM. |
11-09-2013, 11:28 AM | #4 | |
Yeah, I don't know that I would trust the hooks in the stake pockets like that. I'm not sure about the weight holding ability of tie-down straps either?
I have however used a unit that looks rather like the one in Palf70step's pics.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-09-2013, 02:11 PM | #5 | |
The prob I've found using the engine hoist is the boom typically is just barely long enough so you have to be careful. Dually beds are even worse.
11-09-2013, 02:59 PM | #6 |
11-09-2013, 03:25 PM | #7 |
Best Method:
1)Fridge full of beer 3)Thirsty Friends |
11-09-2013, 06:14 PM | #8 | |
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
11-09-2013, 07:03 PM | #9 |
I used the 2x4 approach, but came in from the rear.
We had a 5th wheel hitch in our '75; we would always pick it up from the hitch using the chain fall on a trolley in the rafters. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-09-2013 at 07:11 PM. |
11-09-2013, 08:54 PM | #10 |
You guys spend way too much effort.
Buy an 18-pack and invite 4 buddies over. Give 'em all a beer, shoot the breeze a while, SUPERVISE as they do the bed, give 'em each another beer, then tell 'em you have to go. Tell 'em thanks for their help. You have your bed work done and 10 beers for yourself. |
11-10-2013, 12:35 AM | #11 |
I use the 4 straps at the corners hooked to my chain hoist. Piece of cake, one man operation and I get to keep all the beers to myself.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
11-10-2013, 11:57 AM | #12 | |
11-10-2013, 12:10 PM | #13 | |
I built me a contraption that uses 2 - 2x4's (across front and back) and a 4x4 that bolts to those two and my Hazard Frought cherry picker. I even had a pneumatic/hydraulic ram on the cherry picker so I don't have to jack it, just push the air control and up she goes. If you're going to do it yourself, have a line tied to one corner so you can spin/swivel it as needed. |
11-10-2013, 02:57 PM | #14 |
stepside bed, i do it myself
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
11-11-2013, 03:20 PM | #15 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
11-12-2013, 12:20 AM | #16 |
he wins, dang it
11-12-2013, 01:27 AM | #17 |
Done mine with 2 2x4's stacked together.
Bunch of show offs with nice shops and trucks. I'm jealous of ya'll. NO HARSH SMARTNESS INTENDED GUYS. |
11-12-2013, 01:43 AM | #18 |
Perks of my father and I both standing over 6' tall, we just grab the bed at the bottom of each side of the wheel opening and stand up. Good methods listed here, they all work. Most important thing is to double & triple-check that everything is disconnected.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
11-12-2013, 02:18 PM | #19 |
11-12-2013, 02:44 PM | #20 |
my bed floor is removable. that lightens it up a bit. slide it, lift it and stand it up on the tailgate.
11-13-2013, 10:31 AM | #21 |
Crazy
I used a very similar method to get the cab off my parts truck back in the day. 2 straps on the front door hinge bolts, and 2 straps on the rear on the door striker posts, lifted away, then rolled the frame out from under it. worked like a champ! My straps I was using were rated for 1500lbs each, so I wasn't worried about it at all.
77 SB Stepside in a bunch of pieces scattered around the garage. |
