Old 11-08-2013, 08:58 PM   #1
McCoyAZ
McCoyAZ's Avatar
'64 rear differential....
My old truck is a 64 c10.
The parts house tells me that the '64 is supposed to have a 10 bolt rear end in it and the one I have is a 12 bolt.
They say then if it's a 12 bolt it is from a '63.
They can't seem to tell me which pinion seal I need or which U Joints I need to fix it.
So I need to know when I look for these parts, what year I should be looking at??
It was O'Reiley Auto Parts and a local parts house that couldn't tell me ....
McCoyAZ is offline   Reply With Quote
Old 11-08-2013, 09:32 PM   #2
DPowers
DPowers's Avatar
Re: '64 rear differential....
I thought they were 12 bolts up through early 80's in c10's.
DPowers is offline   Reply With Quote
Old 11-08-2013, 09:56 PM   #3
1963c-10
1963c-10's Avatar
yup, 10 bolts in c10s until 62. 63 went to 12 bolt w/17 spline axle and 30 spline in 65. pinion seal should be same from at least 63-72 12 bolt....thats 1/2 tons
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-08-2013, 09:57 PM   #4
66Submarine
66Submarine's Avatar
The parts house is wrong. (Big surprise, lol) '64 had the 12 bolt; GM changed to the 12 bolt in '63.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 11-09-2013, 10:39 AM   #5
McCoyAZ
McCoyAZ's Avatar
Funny thing is that both Auto Zone and O'Rieley say that the 10 bolt is what is in that truck, not a 12 bolt.
Makes it hard to find parts when the parts guys don't know what they are talking about :-(
Old 11-09-2013, 11:21 AM   #6
Snailed
Snailed's Avatar
Going by the year isn't the best way to do this since these parts could have been changed in the last 49 years.
Wouldn't looking under it and counting the bolts be easier? You could measure the U joints too while you're under there and get all the correct parts on the first try.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 11-09-2013, 12:48 PM   #7
gofastnut
gofastnut's Avatar
Speaking as a parts guy, As long as everything's original(not updated/changed), and a parts house has BOOKS, there shouldn't be a problem getting you these parts.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 11-09-2013, 12:56 PM   #8
gofastnut
gofastnut's Avatar
OK, This is for an auto or 3 speed, 4 speed is different. If you've got a 4 speed, let me know.
with a 3 joint drive line, all three should be the same, Precision #369
with a 2 joint drive line, both should be the same, Precision #369
The pinion seal should be a National #8460N, there's also a #5578, but my money's on the 8460N.
Hope this helps.
Jeff
C-10 Club
Old 11-09-2013, 01:02 PM   #9
McCoyAZ
McCoyAZ's Avatar
If I had the truck where I could crawl under it and count and measure....I agree it would be easier. But it's 20 miles away locked in a garage that I don't have access to.
That's why I was hoping the parts guys had the correct information.....sadly they don't.
Old 11-09-2013, 01:06 PM   #10
McCoyAZ
McCoyAZ's Avatar
Hope this helps.
Thank you very much for this.....I will see if the local parts place has any of this.
The truck originally had a 6cyl with 3 on the tree.
I removed it and put a 283 with a power glide in it. Had the original drive shaft shortened to fit the new configuration but did not change the u joints since the shop guy said they looked great....
The 12 bolt rear end is original to this truck according to the original owner.
Old 11-09-2013, 02:07 PM   #11
gofastnut
gofastnut's Avatar
Then, to the best of my meager calculations, those part numbers for the U-joints and pinion seal are correct.
Good Luck!
Jeff
C-10 Club
Old 11-09-2013, 07:36 PM   #12
50bomb
50bomb's Avatar
I went to Napa for a differential gasket cover. Napa told me that my 12 bolt is not original to my 65 c10 and that it should have a 10 bolt. They said I had a 67 c10 rear end haha. Bunch of bs. They dont know anything now a days. If they actually looked into the books instead of their data base computer they would know the correct stuff.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 11-10-2013, 01:17 AM   #13
Captainfab
60-66 Nut
The GM truck 12 bolt was first introduced in the '63 model year and used in the C10's thru the '82 model year and thru '79-'80 in the K10's and K5's. The '63+ GMC's did use the Dana 44's in the 1/2 tons which did are a 10 bolt. Both the Chevy and GMC's from '55-'62 used the Eaton HO32 differential which was also a 10 bolt, but had a drop out 3rd member.
Old 11-13-2013, 05:54 PM   #14
gofastnut
gofastnut's Avatar
Sorry it took so long to look at this thread again.
Thanks for that info, Captain!
Jeff
C-10 Club
Old 11-13-2013, 05:58 PM   #15
McCoyAZ
McCoyAZ's Avatar
Auto Zone told me the exact same thing.
Local parts house said I had a Spicer rear differential..... geeeezzzzz
