Old 11-09-2013, 03:34 AM   #1
JonCheun
Cool Rusty Radiator Swap
Hi Truck lovers,
I've flushed the cooling system numerous times and it is just time to get rid of the rust once and for all.
I'm replacing my original radiator that is all rusted out with an aluminum replica from Classic Industries. I also have a new Billet Aluminum overflow tank from JEGS to go with the radiator. While I have the radiator hoses off I might as well replace the thermostat so I picked up a 180 F thermostat for my 350 HO Deluxe.
My question since it's been rusty for a while, Should I replace the transmission cooler as well?
The fluid was never milky brown only green with some brown in it but the radiator and overflow tanks were completely rusted. It makes me wonder if the transmission cooler is the same.
I was thinking to replace the radiator and overflow tank for sure. Drive it for a few hundred miles and see if the fluid still has some rust in it then if so replace the transmission cooler. If not, just keep on keepin on.
What do you guys think?
JonCheun is offline   Reply With Quote
Old 11-09-2013, 09:00 AM   #2
Re: Rusty Radiator Swap
The new radiator should have the tranny cooler as part of it like the original. If you had an aftermarket tranny cooler added, then I would just inspect it, but you probably won't need to replace it.
Old 11-09-2013, 10:06 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Keep in mind that the rust didn't come from the rad.It copper and brass if original and wont rust.Therefor the rust is from engine and cooling system components.I would flush the engine as well as possible before replacing rad.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
