Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-09-2013, 12:54 PM   #1
1966burb
1966burb's Avatar
66 Burb needs added towing capacity
My 66 suburban has been lowered in the rear 1 1/2" with blocks and shorter coils in the front. I need to increase the towing capacity for towing my 1959 Shasta trailer. I know of one suburban owner using the TIMBREN overload system. Can I put airbags in the coils? Suggestions? Thanks, Jim
1966burb is offline   Reply With Quote
Old 11-09-2013, 04:28 PM   #2
RANDY COX
RANDY COX's Avatar
Re: 66 Burb needs added towing capacity
Nice Burb.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-09-2013, 07:47 PM   #3
1963c-10
1963c-10's Avatar
why not get a set of factory auxilliary springs. will add 1000lb more capasity to the rear. check out the thread on these are few threads down.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-09-2013, 09:53 PM   #4
NEWFISHER
NEWFISHER's Avatar
What about running overload air bags on your trailing arms just ahead of your springs? Porterbuilt sells a simple bracket kit for the lowrider crowd, but you could use them for the smaller load bags then run seperate airlines back to you license plate bolts and install manual schrader valves to fill when needed
NEWFISHER is offline   Reply With Quote
Old 11-10-2013, 01:34 AM   #5
Captainfab
60-66 Nut
I would just replace the rear springs with air bags. Even if you just ran them with schrader valves.
Old 11-11-2013, 10:26 AM   #6
kieth
kieth's Avatar
I second captain fab, the air bags are the only way to go. You probaly do not have a capacity problem just a ride height problem. With the air bags you get a good ride, and ride height control. When you add heavier springs you have to live with them everyday.........
ps check the tongue weight on the trailer, if it is too heavy you might purchase a load control hitch which will transfer weight from the rear to the front of the vehicle. (the bags will work best) Kieth
kieth is offline   Reply With Quote
Old 11-11-2013, 11:28 AM   #7
1966burb
1966burb's Avatar
Thanks for all the good information. Looks like I have some options. I did start with dialing in the tongue weight and it comes in right around 225.
Old 11-11-2013, 12:33 PM   #8
LT1 Burb
LT1 Burb's Avatar
Just for reference, I installed bags in the rear of mine originally to tow a trailer. The tongue wait was 1400# and it was fine.
LT1 Burb is offline   Reply With Quote
Old 11-11-2013, 12:47 PM   #9
NEWFISHER
NEWFISHER's Avatar
Lets see some more " before" pics!
Old 11-11-2013, 03:50 PM   #10
1966burb
1966burb's Avatar
LT1 Burb. Did you replace the coils with air bags? Or inside the coils? or??
Old 11-11-2013, 04:28 PM   #11
LT1 Burb
LT1 Burb's Avatar
Just replaced the coils with bags, that trailer was heavy, it was a 28' with a 14' front slide. I ran a hitch with equalizer bars and a sway bar but it handled it fine.
Old 11-11-2013, 06:53 PM   #12
1966burb
1966burb's Avatar
WOW. Quite a load. I should not have much problem with my 1959 Shasta. 2820 total pounds loaded. Tongue wt is 360 #s.
Old 11-11-2013, 07:42 PM   #13
lgehring
I have the same type of situation. I have a 66c20 that has had an 8ft farm dump bed with grain sides on it all of it's life. My coils have space between the top and bottom curls, in between is all collapsed and touching each other. The overloads are resting on the trailing arms even when empty. According to the conversation in this thread, I can remove my coils and replace them with air bags?? Which is cheaper, bags or coils? Lowell
lgehring is offline   Reply With Quote
Old 11-11-2013, 09:08 PM   #14
G&R's57GMC
G&R's57GMC's Avatar
Depending what you load in the rear of the Sub. 250# tongue weight shouldn't be a problem.
I have a 13' Casita Deluxe that weighs 2500# loaded on the road with a 250# tongue weight that I tow with my SSR with the bed full of camping gear. To bring it back to normal ride height I added a pair of AIRLIFT air bags inside the rear coils and Schrader valve to the rear.
The hitch is a fixed height Euro style on the SSR. I had to replace the axle on the Casita as it was bent, so I ordered one with a lift to get the Casita level.
The first pic is when I first got the Casita.
The second pic is with the new axle on the Casita and the AIRLIFT on the SSR.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-12-2013, 09:05 AM   #15
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
IF you have a 59 Shasta, it probably is in the 2000lb range, that burb should be fine with a class 2 hitch, if you want to beef it up a tad, use a class 3 hitch and throw some bags under it. This is what I did with my truck ( SWB) with towing a 67 Aristocrat ( 2300#)
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-12-2013, 11:36 PM   #16
Reyals Bemus
I took some old Camaro leaf springs and massaged them to contour the frame and act as overload springs on my '64 panel. They are fastened to the frame rail with two 1/2" grade 8 bolts on each side. They do the job wonderfully.
Truck at ride height, unloaded:
Reyals Bemus is offline   Reply With Quote
Old 11-13-2013, 10:15 AM   #17
LT1 Burb
LT1 Burb's Avatar
[QUOTE=Reyals Bemus;6361176]I took some old Camaro leaf springs and massaged them to contour the frame and act as overload springs on my '64 panel. They are fastened to the frame rail with two 1/2" grade 8 bolts on each side. They do the job wonderfully.
Thats pretty cool, nice job.
Old 11-14-2013, 12:39 AM   #18
Bart Savage
Bart Savage's Avatar
whats the drop combo on your panal and the tire sizes?? looks great...just about what im looking for on my suburban
Bart Savage is offline   Reply With Quote
Old 11-14-2013, 02:14 PM   #19
hemifalcon
Those springs on the rear of the panel look like the very lightweight truck springs as opposed to the HD springs that are typically on the panels/suburbans...
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
