Old 11-09-2013, 11:36 PM   #1
SA_swaps
70Gmc+02 Tahoe= 72
This is my first post on this Forum, have been reading others post, figured I would share my current project. I suppose this has not been done, but will be shortly. Goal well not a goal this is what is going to happen. Have a 70 gmc custom camper and a 02 4x4 Tahoe. Going to use the 70 body and few interior parts and EVERYTHING else will come off of the tahoe, frame, wiper motor, window motors?, push button 4wd,frame mounts, seats, onstar, compass mirror, power locks?, dash harness,engine and harness, basically will look like a 70 but will be a Tahoe. Wheel base is only 1 in different. I know it looks ugly now, but you have to have vision, to see past all the colors. I promise it will look better before long, just trying to get everything mocked up then will come back and make it look nice. So far I have the body mounted on to the Tahoe frame, the wiper motor fabricated to fit, 4wd module, bcm, fuse box,relay box mounted. Working on dash harness and everything now. Even using the glovebox hinge from the Tahoe to make the fuel filler door in the bed.
SA_swaps is offline   Reply With Quote
Old 11-10-2013, 02:06 AM   #2
jmedero
jmedero's Avatar
Re: 70Gmc+02 Tahoe= 72
Should be cool when done. Keep it up
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 11-10-2013, 03:34 PM   #3
SA_swaps
This is how I mounted the cab to the frame, mock up have to get shorter bolts, and finish boxing them in.
Old 11-10-2013, 06:38 PM   #4
higgys72
this is deffinatly ont that i will be fallowing i have been so close to doing this same swap twice now first one i was looking for an escalade but couldnt find on in the right price range and second one i found the tahoe but didnt have the space to do it im stoked to see how it turns out
higgys72 is offline   Reply With Quote
Old 11-20-2013, 12:06 AM   #5
SA_swaps
Trying to keep everything 02 Tahoe, but wiper switch with delay off the Tahoe was not going to work well, so I had a wiper switch out of a 91 Chevy I decided to use instead, fabricated into the 70 housing. Yes I could have bought a switch but, 91 wiper switches never go bad, and a universal pulse switch i figure will. I try to stay away from boxed parts as much as possible. The ignition switch is 02/70.
Old 01-01-2014, 10:14 PM   #6
SA_swaps
Speed hut gauges, still have to put my abs and check engine indicator into the old turn signal indicator spots.
Old 09-24-2014, 12:47 AM   #7
higgys72
Looks good updates?
For more consistent build updates fallow.
http://https://www.instagram.com/timhigginson90/
72 k10 build thread
http://67-72chevytrucks.com/vboard/s...62#post9002062
Old 03-04-2015, 01:07 PM   #8
Farm Shop
Farm Shop's Avatar
Any updates?
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina
1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208
1970 GTO Judge, heads/cam LS1 & stalled 4L60e
Farm Shop is offline   Reply With Quote
Old 03-04-2015, 01:10 PM   #9
Justin@EntropyRad
Justin@EntropyRad's Avatar
cool swap!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 03-04-2015, 09:45 PM   #10
SA_swaps
The wiper switch I was attempting to make work did not work correctly so I ended up using the stock tahoe multi function switch mounted in the dash for the wiper switch only. I still have to get the outside of the truck painted but it is getting closer. Will post more recent pictures of inside later.
