11-10-2013, 11:21 AM | #1 |
Djm lower control arm and drop spindles
I have a 68 GMC that already has Western Chassis 2 1/2 Drop Spindles.
I also have a set of DJM Dropped Lower Control Arms, Djm says you can't run Drop Spindles with there control arm? Does anyone know why or if you can run them |
11-10-2013, 07:12 PM | #2 |
Re: Djm lower control arm and drop spindles
The bottom of the jdm lca's will be too close to to the ground with drop spindles. The jdm's have a 3" drop built-in, I think you can use a 1" -2" drop spring, but I would check with them.
Dano
'69 Fleet It ain't yours, if you didn't build it! |
11-17-2013, 11:10 AM | #3 |
Thanks, I have drop spindles on it now so I will be selling the lower control arms.
I am going to bag it! I have already started changing out the leaf springs to coil |
