Old 11-10-2013, 01:49 PM   #1
primetime
primetime's Avatar
airbags question
are there air bags that could be bolted in place of the stock springs with out the extra elaborate set ups? I am not a welder
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 11-10-2013, 02:03 PM   #2
69StepsideMedic
Re: airbags question
several makers produce these kits that are completely bolt on with no welding necessary
69StepsideMedic is offline   Reply With Quote
Old 11-10-2013, 02:05 PM   #3
MattPSU
MattPSU's Avatar
I'm no welder either, which is why I went with Porterbuilt's Stage 1 front and rear kits. Everything is bolt in. Need to remove a few rivets and drill some holes, but no welding is needed. There are other companies who offer similar set ups, but my experience with Porterbuilt is second to none. I ordered mine from Travis at Pro Performance. Below are links to the front and rear kits. Running mine with schrader valves but you could do a compressor and a tank if you want. I plan to upgrade mine when the funds are available. Travis has several air management options for you as well.
http://www.azproperformance.com/Port...Front-Kit.html
http://www.azproperformance.com/Port...-Rear-Kit.html
You can check out my build thread for some pictures of the kit installed. Good luck! - Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 11-11-2013, 08:47 AM   #4
primetime
primetime's Avatar
thanks guys, that looks affordable.
