rear coil spring d-shaped spring retainers
Hey guys
im putting in my new moog rear coil springs and ece trailing arms. when i put the spring retainer cups in the springs, there is quite a bit of play for the cups to move around inside the spring. is there a specific way to install the cups? and are they clocked a certain way on the trailing arms? thanks! |
Re: rear coil spring d-shaped spring retainers
Here is a thread that should help you
http://67-72chevytrucks.com/vboard/s....php?p=6277335
Scott |
