I have a question about this nipple on the side of the tank i purchased. My best guess is its a return line or a tank vent. but I'm not sure if it is necessary to use or if you just block them off to prevent crap from getting into your tank? below is a picture of the tank, and the other deal is a roll over vent valve please tell me what you all think.
17 gallon rear mount lmc tank ![]() roll over vent valve ![]()
Seth - '66 C10 fleet side w/ '65 327 Build thread http://67-72chevytrucks.com/vboard/s...=1#post6156212 |
Re: Under Bed Mount tank question
What that looks like to me is a vent. What I did with mine was attach a couple of feet of fuel hose to the nipple and put a cheep fuel filter on the end. Took a couple of ty-wraps to hold it above the tank near the fender mounted filler. But I do like the the roleover vent.
...times 2 on the high-mounted filter...and the tie-strap...
Sam |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
You should put a foot or so length of fuel line on it and then get you a differential vent and put it on there so no bugs and moisture get in. Be sure to put it higher than your tank though
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I have the same stainless vent on the water tank of my boat. Bugs and spiders dont get into it.
