Moderator
![]() Join Date: May 2007
In cab heater delete plate
Came across a heater delete plate in a. 60-66 truck. I know the under hood plates are not too difficult to find. How hard is it to find one of these? It's a shame someone drilled a hole in it for an accessory switch of some sort.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Moderator
Re: In cab heater delete plate
Truck it came from.
Hole looks like the factory hole for the thrift air heater. They had a single cable to pull for heat and you twisted/rotated the knob for fan speed. Not rare at all more common than the 3 lever type
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
That is the plate and hole for the "standard" heater control. Its a pull for heat and twist for fan set up. More common than the 3 slot deluxe heater plate.
That isn't really a delete plate. It is the standard dash plate that most trucks came with and the hole is for a control knob. See pic below.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Moderator
Good to know, thanks!
Lol we all responded at the same time!
1961 crewcab
funny, up north here we all had deluxe heaters, for example of the 80+ trucks in the local wrecking yard I think I found 2 with that style of heater... so up here it is rare!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yep, I've only seen 2 or 3 myself over here as well.
This reminds me of a question I have. Under my dash I have the blower unit for the heater and it seems to work. Under the hood I have 2 delete plates where the large black box usually is. What is that thing?
Active duty Navy CPO 1961 C10 SWB 1963 C10 LWB (donor) 1965 C10 LWB BBW |
1961 crewcab
that is the economy, or cheap heater, there should be plumbing from your motor to it, but it is all contained in the cab
Yes I do have heater hoses going into the cab via firewall. I thought I was maybe missing something. I think I will pull it all out and clean it up. I guess there is a heater core in there right?
#13 |
![]() Join Date: Aug 2011
That would be rare here in Arizona also....mine doesn't have any of the heater or air cond. parts.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
#14 |
60-66 Nut
Yes you have a heater core. Everything is inside the cab with the recirculating heater. Your heater controls should have only 2 levers/knobs.
