11-10-2013, 11:21 PM | #1 |
sbc to bbc
im planning on going from a 350 to a 468 in my k10 i am wondering what all will need to be changed. will my motor mount locations stay the same? throttle cable? i know my exhaust will not line up and will need to be redonesome what. also have lots of questions about doing a tbi swap i have all parts for both swaps i think. i mean i have a running suburban with a 468 bbc with a tbi set up and a running non driving 72
For more consistent build updates fallow. http://https://www.instagram.com/timhigginson90/ 72 k10 build thread http://67-72chevytrucks.com/vboard/s...62#post9002062 |
11-10-2013, 11:30 PM | #2 |
Re: sbc to bbc
also what would i be better doing fuel injecting the motor i built and changing the cam in the bbc and droping it in my nova or giving the truck the bbc the way it is and giving the nova the sbc out of the truck. the bbc is dynoed at 353 hp 493 ft/lbs tq and the sbc i have no idea its a 30 over with 10.25:1 cr with vortech heads and mild cam. the sbc is original to the truck and ill more than likely have both cars forever. im looking for what ever option make the truck the most enjoyable nova gets the handme downs.
11-11-2013, 01:37 AM | #3 |
Re: sbc to bbc
Some say something about the heater box. May have to take it out. But I dont know for sure. think only when using tall valve covers. Dad used to swap mine out from sbc to bbc all the time back in the day. Just the motor mount stands and exhaust were the issues. go for it. original? so? Throw it to the side for later if anything. Have some fun. Original will make it just like the rest lol
11-11-2013, 10:12 AM | #4 |
2WD Jimmy
Re: sbc to bbc
Dont forget to do a forum search on this subject. Alot of people on here have done this!
12-18-2013, 09:02 PM | #5 |
Re: sbc to bbc
http://67-72chevytrucks.com/vboard/s...d.php?t=565381
http://67-72chevytrucks.com/vboard/s...=263273&page=4 http://67-72chevytrucks.com/vboard/s....php?p=5888239 http://67-72chevytrucks.com/vboard/s...d.php?t=225845 good info right there....... Heater box wasn't an issue for me. I had to redrill and move everything back 2.5" back. PITA |
12-18-2013, 09:18 PM | #6 | ||
"I ain't nobody, dork."
Re: sbc to bbc
Only 353 hp and 493 ftlbs out of a 468? Stock rebored engine?
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
12-18-2013, 09:22 PM | #7 |
Re: sbc to bbc
I used motor mounts from POL (Performance Online) . I bolted them in the front set of holes. No valve cover or HEI problems. I don't have a lot of room for electric fans with a 4 row radiator, but I found a set that should work. I used Hedman full length big tube headers and had to do a little frame massaging, but they do hang pretty low for a dropped truck.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
12-19-2013, 10:05 AM | #8 | |
Re: sbc to bbc
sounds a little weak to me
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
01-05-2014, 12:53 AM | #9 |
Re: sbc to bbc
Looked at the engine build sheet agaid the performance figures are projected not actual and it dosent say rwhp or crank hp. Here's the specs what do you guys think on performance.
Bored 60 over C/r8.73:1 2.19 intake valve 1.88 exhaust .501 lift intake and exhaust 214 @.050 duration 109 119 lobe center Completely blueprinted and ballanced within 2 g Edelbrock performer heads 110cc combustion chamber 1.7 rockers turbo city tbi system 14psi fuel press Crane high out put coil and box Cam 4deg advanced
