Old 11-11-2013, 02:26 AM   #1
18436572GMC
18436572GMC's Avatar
HO72 Gear Lube
Just like the title says what gear oil should I run? Also about how much does it hold? I figure any GL-5 between 75w90 and 85w140 should be fine but want to be sure.
Real trucks have a clutch. Please inform automakers.
1972 GMC, K25, 383 stroker, SM465, NP205, Eaton HO-72
18436572GMC is offline   Reply With Quote
Old 11-11-2013, 12:54 PM   #2
c20pickup
Re: HO72 Gear Lube
i used regular gear oil, 75-90 i believe. I pull the plug and filled it until it came out the hole.
c20pickup is offline   Reply With Quote
Old 11-11-2013, 11:56 PM   #3
18436572GMC
Re: HO72 Gear Lube
ttt
Old 11-13-2013, 10:36 PM   #4
heyjoe
Re: HO72 Gear Lube
According to my '67 Chassis Service Manual:
Lubricate with Multi-Purpose gear lubricant meeting requirements of U.S. Ordnance Spec.
MIL-L-2105B
Below 10F SAE 80
Up to 100F SAE 90
Above 100F Consistently SAE 140
No fill capacity in print that I can find.
Several years ago, I filled my bone dry HO52 with approx. 3qts. give or take. (Beware! my memory may be faulty!). I say "bone dry" because I had the rear end apart for a carrier swap and total clean and scrub to remove metal dust and particles.
I used 80/90 GL-5 gear oil.
Hope this is of some use.
heyjoe is offline   Reply With Quote
Old 11-13-2013, 10:44 PM   #5
swamp rat
swamp rat's Avatar
Re: HO72 Gear Lube
Regular gear lube, but from what i have been told if you have the no spin diff you need a limited slip additive, available at your local auto parts store.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-13-2013, 10:48 PM   #6
Longhorn 70
Longhorn 70's Avatar
Re: HO72 Gear Lube
2½ is in my memory for some reason. It has been a while and I want to say the brand name was JL-7??? Some red goo that my uncle used to use in semi rear diffs.
I bought 3 quarts and tried to put it all in but it was oozing out of the fill hole. I was on a slanted driveway though. Like C20pickup said, fill until it oozes out. Put the plug in and drive away.
Good luck buddy.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 11-14-2013, 01:10 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: HO72 Gear Lube
Pretty sure 3 qt. will fill it and maybe have some left over. I used Mobil-1 full synthetic 75W-90, but any brand will do the job, and dino is okay too. I just preferred synthetic.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
