Spider rings on stock rims??
Don't suppose anyone knows if the spider rings that Rallye America or Gambino's sells will fit on a stock rim?? The ads say they fit a 10 1/8 hub cap. Are these what the stock rims are?? My panel is 10 miles away, and I don't have a stock rim handy to check. These are the small trim rings, NOT the spider caps.
Senior Enthusiast
Re: Spider rings on stock rims??
Yes those will fit stock Chevy truck rims if you have the standard 6 lug wheels with 3 hub cap bumps, or the later disc brake wheels that have 4 hub cap bumps (both 5 & 6 lug). 10 1/8” hub caps were the standard on Chevy passenger cars from 1954 and newer, and Ford passenger cars from 1949 and newer. The GM 1/2 ton truck hubcaps also used the standard 10 1/8" size as well when they finally eliminated the clip mounting. Those spider rings won’t work on the 1960-61 (and earlier) rims with hub cap clips.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
