Old 07-13-2003, 12:09 PM   #1
WB72
Before and After
WB72's Avatar
How do I convert a 3/4 ton to 1/2 ton suspension?
I have a donor rolling 71 C10 frame that I would like to use the suspension from on my 72 C20. What peices do I need to take from the C10?
Front:
Will I need ball joints and tie rod ends as well as the upper and lower control arns to fit the C10 spindle?
Rear:
Both units have coils, will the rear end simply replace the C20 unit?
I will be using new springs both front and rear, but I believe the C10 and the C20 can interchange, is this correct?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 07-13-2003, 12:23 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
When I changed mine over I unbolted the whole 3/4 ton cross member and swaped it with the 1/2 to bolted right in. As for the rear just unbolt the axle and swap it out with the 1/2 ton . The only problem I had was different rear brake line set-up ,which I have not resolved yet. Did I miss anything.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-13-2003, 06:30 PM   #3
crazy longhorn
Fabricate till you "puke"
The crossmember, & the upper a arms will work from the c 20. You need to swap the lower a arms(due to ball joint size), & the balljoints ,spindles ,ect from the 1/2 ton truck. If you have the steer linkage, you will be ahead of the game. I dont think you will find a difference in the center link, but the outer tierod ends will be different on the 1/2 ton. at the rear, the diff will bolt in, but I beleive you will need the track bar & bracket from the 1/2 ton truck to make the swap complete. u joint sizes will also be different, as well as d shaft lenghts. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-13-2003, 07:59 PM   #4
spinning wheels
spinning wheels's Avatar
Other than not having the 8 lug wheels. What advantage would you get installing smaller suspension parts?
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 07-13-2003, 08:06 PM   #5
crazy longhorn
[QUOTE]Originally posted by spinning wheels
Other than not having the 8 lug wheels. What advantage would you get installing smaller suspension parts? [/QUO A lower stance, smoother ride, less unsprung weight.......& a more fun truck crazyL, rowin 6 of em, with a big @ss smile
Old 07-13-2003, 09:42 PM   #6
WB72
Before and After
WB72's Avatar
The biggest advantage, for me, would be to be able to get drop spindles.
66,000 miles.
Alberta, CANADA
