Old 11-11-2013, 01:31 PM   #1
rs74
rs74's Avatar
No start or power at key but have lights.
Went today to back the K30 out of the shed and I had nothing at the key. I have headlights when I turn them on but nothing in the cab. No glow plug light, wont turn over or anything. The truck has been starting up just fine. It has been sitting in the shed for three or four days without being started. Not sure why all of a sudden I have this condition. I have taken the dash pad off and have been getting ready to revamp the heater box but that is it.
Ignition switch, starter soleniod or wire? My 03 2500HD fuel pump went out and was going to back the K30 out and put the 03 in. Guess I will be working on this first. Any ideas?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 11-11-2013, 03:10 PM   #2
4x4k30
4x4k30's Avatar
Re: No start or power at key but have lights.
if you have a automatic shift the lever to p and n sometimes the netural switch will hang up if u have a 4speed check clutch pedal switch they will hang up to.
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 11-11-2013, 03:20 PM   #3
rs72z
rs72z's Avatar
Check the fusible link on the firewall or at the starter.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 11-11-2013, 05:23 PM   #4
rs74
rs74's Avatar
Found it. I took my screwdriver and jump across the post on the firewall link/transfer block and it must have a bad connection. I am going to have to take it apart and clean it. I had left the key on with the heater on high so when I came across the issue it would turn the blower fan on and I would know what the problem was.
Roy
1987 R10 shortie
Old 11-13-2013, 08:29 AM   #5
TDS-MN
I was going to suggest looking there, I had the same problem, and finally a friend found that I had a broken wire at that junction. Glad you found the solution.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
