Old 11-11-2013, 07:11 PM   #1
jackson
ad speedometer
I want to run the stock ad speedo and I have a 700r4. what to do? do they make a cable that will work? trans is an earlier one with a gear in it
jackson is offline   Reply With Quote
Old 11-11-2013, 07:34 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: ad speedometer
My cable in my 50 was long enough and threaded into the 700r4. Yes the make longer cables, but your will most likely work if its the stock length.
NEWFISHER is offline   Reply With Quote
Old 11-11-2013, 09:54 PM   #3
Clay54
Re: ad speedometer
I also have a 700r4 ('89) but I think it is an electronic speedo connection. Can you change to the gear to use with the AD speedo? Thanks, Clay
Clay54 is offline   Reply With Quote
