Old 11-11-2013, 08:32 PM   #1
stingray_76
What is this?
What is this? Why was it unplugged? Do I need it? Does it explain why my turbo 400 tranny won't downshift at WOT? What colour wires should be looking for to connect it?
Got an 87 1/2 ton with a 305 tbi.
stingray_76 is offline   Reply With Quote
Old 11-11-2013, 09:21 PM   #2
beamn7
Re: What is this?
Yep! That is the kickdown switch for a THM-400 One side should have key hot power, the other side should get power when the gas pedal is fully depressed, sending power to the single spade connector on the side of the transmission which engages the kickdown solenoid inside the trans.
beamn7 is offline   Reply With Quote
Old 11-11-2013, 09:53 PM   #3
stingray_76
Re: What is this?
What colour are the wires for the original connection in the cab?
And if I have this, why do I have a vac modulator on the RH side of the tranny?
Old 11-11-2013, 10:19 PM   #4
willett
Another Day, Another Dollar
willett's Avatar
Re: What is this?
Orange and white I think
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-11-2013, 10:35 PM   #5
4x4k30
4x4k30's Avatar
Re: What is this?
that is the kickdown switch for the turbo 400 i think it has red and white wire ran to it.. the wire that goes down to the transmission is orange. if you dont have a turbo 400 you dont need it.. the turbo 350 and 400 both have a vacum modulator thats what causes it to shift .
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 11-12-2013, 01:09 AM   #6
beamn7
Re: What is this?
THM-400 uses an electric kickdown whereas the THM-350 uses a detent cable aka kickdown cable. Both transmissions use a vaccum modulator as noted by 4X4k30, a modulator has more control over upshifts. Wire it back up and you will have downshifts again.
Old 11-12-2013, 01:19 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: What is this?
Pull the shifter down. Isn't required.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 11-12-2013, 11:34 AM   #8
ironroad9c1
Master Hater
Re: What is this?
yea the arm on my pedal won't even reach my kickdown switch.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 11-13-2013, 10:51 PM   #9
stingray_76
Re: What is this?
I can't find the harness in the cab for the kickdown switch for the life of me.
The tranny still had the harness end with orange wire attached. Was only about 6" long. Found what I believe is the other end cut off up on the fire wall. Ran new wire to connect the 2 ends.
Where should I be looking in the cab?!
I'd really like to get this thing working. Truck is gutless and terrible on fuel.....
Old 11-13-2013, 11:26 PM   #10
4x4k30
4x4k30's Avatar
Re: What is this?
the switch is located rite around on top of the accelerator foot pedal inside the cab. but it could be gone or your truck may have not had a turbo 400 in it and it was swaped in. and really this switch is just for it to go into passing gear it doest control the shifting. it only kicks in at full throttle ,
Old 11-13-2013, 11:47 PM   #11
stingray_76
Re: What is this?
The switch was there, but absolutely no wiring for it. At least not any I can find.
Where would the wiring typically be?
Old 11-13-2013, 11:55 PM   #12
4x4k30
4x4k30's Avatar
Re: What is this?
i will look on my 79 tomorrow and see what i can find out for you
Old 11-15-2013, 04:34 PM   #13
4x4k30
4x4k30's Avatar
Re: What is this?
here is a pic of the wires going to it. they are orange and pink with black stripe
