11-11-2013, 09:27 PM | #1 |
14 Bolt Read End Drum Brakes Removal?
The rear brakes on my 1973 Chevy C20 Custom Deluxe 454 need replaced, I've removed the drums on my 1978 Z28 before but they were nothing like the drums on my C20's 14 bolt rear end. Any helpful hits on drum removal or step process?
11-11-2013, 09:52 PM | #2 |
Re: 14 Bolt Read End Drum Brakes Removal?
It's a bit more involved than a Z28. To start, you have to pull the axle. Then there is a clip, a key and 2 nuts on the spindle you need to remove. There is a washer in between that ha ears on that you have to bend out, once they are removed, you can remove the outer bearing. Then the whole hub/drum. If you need to replace the drum, you will have to drive out the wheel studs. Be careful driving them out. Use something soft to protect the threads. I use heavy strips of aluminum that I happen to have. Brass works too.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
11-11-2013, 10:09 PM | #3 |
Another Day, Another Dollar
I use an old lug nut to drift out the studs. Don't forget to have a drip tray under the hub when you slide the axle out, you will lose a couple ounces of gear oil per side. Don't forget to buy new axle seals as well. I always do hub seals too regardless of wether or not they are leaking
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
11-12-2013, 12:42 AM | #4 |
If we are also talking replacing the wheel seals, here is an excerpt from a previous thread and my experience with leaking seals ruining brakes:
Just a note about your oil leak. I have an 83 C20 3/4 ton and had differential oil contaminate my big rear brake shoes. I had new "wheel seals" installed (I call them axle seals) and the seals leaked a few months later. The first time the leak was not too bad, the second time it was massive, and I needed to replace those expensive rear shoes. The leak was caused by defective GM wheel seals. If you search the internet, you will find even late model floating axles on GM trucks with leaking seals. GM has since come out with a new 2 piece seal (works like a bearing with an inner and outer race), rather than the 1 piece rubber seal they have traditionally used. This fixed the leak problem. I don't know if your Dana 70 is a floating axle, but I would look into fixing the leak first - and get the new 2 piece style seal if you have a floating axle. All seemed to agree that soaked shoes could not be cleaned effectively - in my case, I found out because I had no brakes at all when trying to stop. I think the 2 piece seal is GM part number 15823962 but I am not sure, so check to see if it is really a two piece seal. All I know is that the standard one piece seal cost me a lot of money in ruined parts and unnecessary labor. |
11-12-2013, 02:59 AM | #5 |
Starting at post 224, in this thread, Tx_Firefighter starts to outline his 14 bolt axle and brake rebuild, darn good reading and axle porn in his thread.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
11-12-2013, 11:28 AM | #6 | |
11-12-2013, 11:30 AM | #7 |
Master Hater
depending on the year the drums will ether slip off ,like your camaro or the hub is part the drum and like someone said , you will have to pull the axle shafts and remove the spindle nuts like the front hubs on a 4wd.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
11-12-2013, 01:37 PM | #8 |
It's not really a big deal. I can have both sides done in well under 2 hours.
The tire shop your talking probably doesn't know you have a full floater.
11-12-2013, 01:57 PM | #9 | |
i don't know 'bout $60 bucks to do pads on a 14b, lot of work for the money. sounds sketchy for your ability to SAFELY stop as mentioned, pull the clips & key, nuts & unbolt your axles good chance you'll find something like this if your not replacing your drums, at least change your seals, it's why my brakes fubared do you really want to scrimp in this area? i junked everything |
11-12-2013, 07:00 PM | #10 | |
11-12-2013, 07:15 PM | #11 | |
Hey, that's up my way.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
11-12-2013, 07:30 PM | #12 | |
No, you don't have to remove the differential cover. The axles un-bolt from the outside, there are no "clips" holding them in.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-12-2013, 08:59 PM | #13 | |
undo these 8 bolts, tap the axle with a hammer & they slide right out. then the lock washer, spindle lock nut, another washer, & another nut. you can see the spindle nut, you will need a special socket, or use a screwdriver & hammer & tap it out. once there all out pull off the drum |
11-13-2013, 12:25 AM | #14 | |
11-13-2013, 01:02 AM | #15 |
Here is a youtube video on how to get 'er done. He has some clever techniques for special method of seal removal (about 7:50 minutes into the video.) Plus, you can see the proper clothes to wear for this task - same thing I wear when going to the pick and pull.
11-13-2013, 10:59 AM | #16 | |
11-13-2013, 01:02 PM | #17 |
I wish I could take a pic/video of it, but I have a much faster way of pulling that inner seal.
Tools required, reasonably long handled prybar (18"+) and a length of 1" pipe or a section of shovel handle, something about 3' long that fits through the hub. After it's off the truck, remove hub from drum. Insert pipe/handle into hub longitudinally, in the outer end and up to the seal, take prybar and hook under seal, bracing against opposite edge of hub, pipe and prybar are approximately 100 degrees from each other, now pull together. The longer the prybar, obviously the more leverage you have, but I can pop those seals out in seconds with this method. If you use the shovel handle or something similar you are guaranteed not to F--- up the race that is pressed in the hub, but even using the pipe I haven't dinged/marred one up. If you have a bench vise that isn't going anywhere (i.e. securely anchored) you can put the hub in the vise and pry the seal out that way too, no pipe/handle required.
11-14-2013, 11:02 AM | #18 | |
