Old 11-11-2013, 09:30 PM   #1
64shortboxchevy
What fittings do I need to connect my trans lines to radiator?
I started running new transmission lines yesterday. 5/16 line with fittings and flared ends on both ends. The lines connect fine to transmission but when tightened to radiator the line has nothing to "crush" against to get tight. Here are some pics. When the fitting is tight in the radiator the line itself is noth and it will leak.
[IMG][/IMG]
[IMG][/IMG]
64shortboxchevy is offline   Reply With Quote
Old 11-11-2013, 11:07 PM   #2
MARTYZ
MARTYZ's Avatar
Re: What fittings do I need to connect my trans lines to radiator?
Pipe thread to inverted flare adapter, believe its 1/4 pipe.
MARTYZ is offline   Reply With Quote
Old 11-26-2013, 03:58 PM   #3
64shortboxchevy
Thanks, got some.
