Old 11-11-2013, 10:25 PM   #1
062500hd
modern snow plow install?
has anyone ever fit up a newer fisher or boss snowplow to a 67-72 instead of the old speedcast fishers?
062500hd is offline   Reply With Quote
Old 11-12-2013, 02:03 AM   #2
cwilkie
Chance
cwilkie's Avatar
Re: modern snow plow install?
Yes. I have a 2012 8' 2" boss power VXT on my 1972 3/4 ton 4x4. The boss dealer had to modify a 73 and up front mount to my truck. I used it all last winter with no problems. It can be done.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 11-30-2013, 09:16 PM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I modified '81-up Chevy full size truck Western Ultramount brackets to fit my '72 1/2 ton 4x4. I ended up rebuilding the brackets to match my factory tow hook holes in the frame horns. Our trucks are also a little shorter (1.5"?) from front spring perch to axle centerline so I had to modify the Western kicker brackets a little also.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 11-30-2013, 10:56 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
I wouldn't put a plow on a truck that I didn't plan on taking to the crusher in a couple of years. Snow and salt destroys plow trucks in no time flat.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-30-2013, 11:51 PM   #5
badpeanut
badpeanut's Avatar
Salt is nasty. I only do my property (no salt); the snow is nothing to worry about.
'70 GMC LWB trailer
Old 02-13-2015, 11:18 AM   #6
Dale_Brown
Do you have a picture with the plow on your truck? Please post?
Dale_Brown is offline   Reply With Quote
Old 02-13-2015, 11:43 AM   #7
This is a Western mount made for an '84 GM Truck I mounted in '84. I ended up doing two trucks that way. Due to the peaked nose on a 67-72 the mount needs to slide forward a couple inches and one hole on each side was drilled. I welded a tab for a stop against the back of the mount on the frame. It was designed to sit back against the spring mount as a stop. Anything made for a square body can easily work on these trucks. I don't know about anything newer,
Old 02-13-2015, 01:39 PM   #8
kampfitt
Yes We put Curtis 3000 7 1/2 on our 72 took the mount off 96 chevy shortened it added 1/2" side plates and kickers to front cross member used it for home and church parking lot for 3yrs works great and love the quick on and off! Also added dual Batt set up with issolator run the plow,dump box,lights off that batt
kampfitt is offline   Reply With Quote
Old 03-14-2015, 12:38 AM   #9
badpeanut
badpeanut's Avatar
Here are two I have on my computer:
'70 GMC LWB trailer
Old 03-14-2015, 09:33 AM   #10
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
You've gotta check out the "chum bucket" build by 115-k10. He put a 7'-6" Fisher MM2 on his 1970 short bed. I believe he used push plates from a 73-87 with modifications. Looks awesome, I'd love to have that setup. Start around post #126, and some more pics around post #180
http://67-72chevytrucks.com/vboard/s...=329775&page=6
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 07-30-2016, 09:34 AM   #11
RestoreAmerica
So this plow frame mount to your frame with only those 3 bolts on each side and the custom kick plates on each side?
Did you notch out your bumper?
How long did it take you to modify the plow frame and install?
RestoreAmerica is offline   Reply With Quote
Old 07-30-2016, 11:55 AM   #12
mrein3
mrein3's Avatar
As previously pointed out, only do your own, unsalted driveway and you'll be fine. I've plowed my driveway and the lake road (no salt there either) for years.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-30-2016, 11:58 AM   #13
mrein3
mrein3's Avatar
One of the best days of the year is when the plow comes off.
Also, if you do plow, I quit screwing around by pushing snow without chains. A set of chains on the front tires, 500 or so pounds of sand bags in the bed, and you're good to go.
'72 Malibu hard top
Center City, MN
Old 07-30-2016, 12:06 PM   #14
mrein3
mrein3's Avatar
Regarding mounting the plow mounts. I quit removing the piece bolted to the frame every spring. Its a PITA to get off and put on. On my mount it is bolted to the frame with 1/2" bolts. The part I call the "plow frame", the heavy metal piece that the lift cylinder is hanging from and has lights mounted on, is bolted to that piece under the truck with four 3/4" bolts, two on each side.
Now that I leave the bottom piece on putting the plow on in the fall is easy. Four big bolts to put the plow frame on, then I drive to where it is laying in the weeds. Three pins hold it to the mounting points, connect cables, and I'm ready for winter.
I should say easy after installing the hydro motor. That sits on the LHS frame rail, really close to the alternator and the wheel tub.
Remember, you are pushing snow. Not bashing in to it (unless you like breaking things). It doesn't take much to hold all that stuff together unless you are beating the crap out of it.
'72 Malibu hard top
Center City, MN
Old 07-30-2016, 04:00 PM   #15
RestoreAmerica
I would be grateful if you would post some pictures of your frame mount.
Thanks in advance!
Old 07-31-2016, 09:32 PM   #16
mrein3
mrein3's Avatar
First is what I call the plow frame. It bolts to the piece bolted to the truck frame. Two 3/4" bolts per side. It has the lights just above the picture. Sorry about cutting them off the picture.
'72 Malibu hard top
Center City, MN
Old 07-31-2016, 09:34 PM   #17
mrein3
mrein3's Avatar
This is a close-up of the left front of the piece I leave on the truck. Somebody welded it in place as you will see in a later picture. I cut a few notches to get wrenches in to work the bolts.
It appears a guy put 2x4" steel tubes inside the frame then welded the plate on that.
'72 Malibu hard top
Center City, MN
Old 07-31-2016, 09:37 PM   #18
mrein3
mrein3's Avatar
This is a picture of the left hand side taken back a few more inches. It shows how the guy welded a "V" that goes back and bolts to the frame back by the engine cradle.
You can see where the plow frame bolts to and the hole the back of the plow pins to.
'72 Malibu hard top
Center City, MN
Old 07-31-2016, 09:40 PM   #19
mrein3
mrein3's Avatar
This is shot where you can see where the back of the "V" bolts to.
I just realized if I put in a 700r4 and move the engine forward I may have other things to contend with.
And yes that is a blue oil pan. Over the 4th I pulled the 383 to deal with my schlecht crank shaft. That is the original 307 out of my 72 Chevelle. It got a blue paint job when it was installed in a 1977 Impala. Long story.
'72 Malibu hard top
Center City, MN
Old 07-31-2016, 09:43 PM   #20
mrein3
mrein3's Avatar
And finally the right hand side. The reason I think it was welded in place in the previous truck is that the guy I bought it from cut this side. I used a hunk of plate and a couple of bolts to make it removable.
'72 Malibu hard top
Center City, MN
Old 07-31-2016, 09:44 PM   #21
mrein3
mrein3's Avatar
I hope the pictures help. It is hard to see with it all in place.
Still one of the best things I've done for myself. My driveway was a bear to clear. Now I do it from a heated cab. And having a road on the lake to the fish house is priceless.
'72 Malibu hard top
Center City, MN
Old 08-09-2016, 12:15 PM   #22
RestoreAmerica
I purchased a 1992 half ton Silverado with a plow. Obviously the plow frame would not fit as it was.
[IMG][/IMG]
I purchased some plow push plates from 73-87 Chevy pickup.
[IMG][/IMG]
[IMG][/IMG]
We used the front portion from the 92 and the part that attaches to the truck from the 73-87. We cut them and welded together.
[IMG][/IMG]
Put a wire wheel to it then treated it with Eastwoods Fast Etch.
[IMG][/IMG]
[IMG][/IMG]
Old 08-09-2016, 02:16 PM   #23
RestoreAmerica
Only had White Epoxy so that is what we used.
[IMG][/IMG]
Followed by a couple of coats of Satin Black
[IMG][/IMG]
Old 08-17-2016, 05:04 PM   #24
RestoreAmerica
[IMG][/IMG]
[IMG][/IMG]
