Old 11-11-2013, 10:27 PM   #1
Bhelton
Bhelton's Avatar
LS conversion
ok, I'm posting a 6.0 package deal up for sale. This is from a 67 project that im working on and we've decided to change directions on it.
Engine is a 06' Denali 6.0 rated at 385hp, harness has been sent to Jims Performance and been modified correctly and computer tuned and I went ahead and installed a new water pump. What's included with it is BBK ceramic headers, prothane ls conversion mounts, Old Air AC Bracket and a new Saden 508 AC compressor. Engine has been cleaned and painted, you will get everything mentioned above and the drive by wire pedal and MAF sensor.
Also have a Griffin LS conversion radiator with dual electric fans designed to be a direct fit for 67-72 trucks
The transmission a TH400 has been professionally rebuilt with a shift kit and is very strong, for the conversion I used a PRW flexplate to adapt the 2 together as well as a new torque converter. The tranny includes a Lokar floor shifter, floor shifter boot and also have the driveshaft that was rebuilt and balanced by Carolina Powertrain.
If someone wants to buy components I will split engine from tranny and separate the radiator but would rather see it all go at once.
As for the package deal asking $4500 or $5500 with the complete Old Air ac system
Will also include MSD fuel pump and corvette regulator, only used item is engine the rest is new parts
pics of parts can be found in this thread
http://67-72chevytrucks.com/vboard/s...=555539&page=2
Bhelton is offline   Reply With Quote
