Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 11-11-2013, 10:41 PM   #1
MetroDPS
Post Stuck? Here is a little info from Dirty jobs
I was asked about something in another thread and rather than cloud that thread I decided to post a new thread. In the mountains here in Colorado you might not see another vehicle for several hours or longer in winter. This is some thing any one who wheels should know! Lives have been lost to chains breaking or straps stretched and breaking. Lets all be safe out there and remember to pack out more than you pack in!
What is your wenches max load rating???
1) Most people are terrible at actually estimating the gross weight of their rig as it sits on the trail, full of gas, tools, equipment, food, camping gear, people, the dog...everything. Heck, in some cases the real figure can actually exceed the GVWR of the vehicle. Simple advice here - either err WAY on the heavy side, or get your rig weighed in trail trim.
2) More importantly, the "effective weight" of a "stuck" 4x4 is very often FAR more than 1.5 times the GVW. The following data on how to more accurately estimate the "effective weight", is taken from the world of professional heavy recovery - the guys that recover Tractor-trailers that have flipped on their side for instance, as well as U.S., Canadian, and UK Military recovery manuals.
Once you have accurately estimated or measured the trucks loaded weight (LW) you can calculate the resistance to be overcome in any recovery situation (this is commonly known as the ROLLING resistance). There are 4 types of resistance that must be accounted for to accurately assess the resistance that must be overcome. These are surface resistance, damage resistance, mire (stuck) resistance and grade (slope) resistance. Calculate them all as follows:
Surface resistance
A pull of 1/10 LW will cause a free wheeling truck to move on a hard, level surface.
A pull of 1/3 LW will cause a free wheeling truck to move on a softer surface, such as grass or gravel,
Damage resistance:
A pull of 2/3 LW will be required to move if the wheels cannot rotate (as if the brakes were fully applied), the pull required to overcome the resistance (drag) the truck id 2/3 or 67% of the LW. Damage resistance includes surface resistance (i.e. you only use one or the other)
Stuck (mire) resistance:
A pull of 100% of LW will be required if the truck is stuck to a depth of the sidewall on the tires.
A pull of 200% of LW will be required if the truck is stuck to the hubs.
A pull of 300% of LW will be required if the truck is stuck to the frame..
Mire resistance includes damage resistance (i.e. you only use one or the other)
Grade (slope) resistance:
Upgrade (vehicle has to be recovered up a slope or grade)
15 degrees - add 25% of LW
30 degrees - add 50% of LW
45 degrees - add 75% of LW
Vehicle recovery on level ground - no correction
Downgrade (vehicle has to be recovered down a slope or grade)
15 degrees - subtract 25% of LW
30 degrees - subtract 50% of LW
45 degrees - subtract 75% of LW
Final figure:
Add surface or damage or mire resistance and grade resistance, and this is your final figure or rolling resistance. This is the amount of pull the winch must apply in order to recover the stuck vehicle.
Here is the military approach.
The way to attack the situation. Using this method you can free a Hummer buried up to its axles Thanks to Mike Rowe and Dirty jobs.
If you want to read on recovery operations search for:
FM 9-43-2, Recovery and Battlefield Damage Assessment and Repair.
MetroDPS is offline   Reply With Quote
Old 11-12-2013, 12:46 AM   #2
joe231
joe231's Avatar
Re: Stuck? Here is a little info from Dirty jobs
Excellent info!!
But I can't believe how many people spell "winch" incorrectly....
CHEVY ONLY
Old 11-12-2013, 01:05 AM   #3
MetroDPS
I am sorry please don't beat me to hard.
Old 11-12-2013, 01:35 AM   #4
joe231
joe231's Avatar
Haha!!
CHEVY ONLY
Old 11-12-2013, 10:28 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
He may not have spelled it incorrectly. My "wench" can pull things rather well...man is she good....LOL!!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-12-2013, 01:34 PM   #6
Coley
Coley's Avatar
Smile Re: Stuck? Here is a little info from Dirty jobs
.....LOL.....
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
