Old 11-11-2013, 11:26 PM   #1
1972SUPERSB
1972SUPERSB's Avatar
Question about horn button retainer
I bought a new steering wheel and a horn button retainer kit. I know this has been talked about before. My question is what order does the spring, spring rod and plastic piece go into the steering wheel that touches the signaling cam? Its the 3 pieces on the right. Then also how does the steel concave washer sit on the spring that make contact with the horn? Can't figure it out
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 11-12-2013, 12:21 AM   #2
68c10airstream
68c10airstream's Avatar
Re: Question about horn button retainer
Hi Jeff, been many years since i was into my steering wheel. But here it goes, spring in the hole first, silver nail like piece goes on top of spring, head down, small clear ring seats on top and through the nail stem pushed into the housing and seated flush (preventing the nail from flying out of the hole when you remove the wheel). Then the cupped spring steel sits into the steering wheel well with the center area sticking up, the silver cupped piece goes on top of the concave spring steel piece. All of this is held in place with the red piece and screws. Hope this helps. Probably been 10 years since i was inside one but gm, jeeps,amc, had that style. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 11-12-2013, 12:45 AM   #3
1972SUPERSB
Talking Re: Question about horn button retainer
You explained it pretty clear. I'm gonna try to put it together tomorrow. Thanks a bunch!
Jeff
Old 11-12-2013, 11:20 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Question about horn button retainer
This may help also.
Thread link.
http://67-72chevytrucks.com/vboard/s...d.php?t=560844
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-12-2013, 11:53 AM   #5
1972SUPERSB
Thanks but in my searching everyone said this was wrong from the LMC catalog. But I appreciate you posting this!
Jeff
Old 11-12-2013, 01:52 PM   #6
Andy4639
Old member
Andy4639's Avatar
Exclamation Re: Question about horn button retainer
The only part wrong is the square#6. Part #8 should be last to install. If you will read the link I explain it also. If u just look at the picture then yea your right.
Old 11-12-2013, 02:20 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
The last time i called,I even asked the LMC rep if they were ever hoing to change the illustration! "Uhhhhhhh"
WIDESIDE72 is offline   Reply With Quote
Old 11-12-2013, 02:32 PM   #8
1972SUPERSB
Thumbs up Re: Question about horn button retainer
Haha! They have no idea
Jeff
Old 11-12-2013, 03:01 PM   #9
swamp rat
swamp rat's Avatar
Isn't the arrangement order incorrect in the #9 box as well?? I thought the pin went in first, am i wrong??
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-12-2013, 11:23 PM   #10
1972SUPERSB
I tried installing tonight but the concave washer that makes contact is supposed to bend down when you push the horn button. Well it pushed down then stayed there. It's supposed to come back up everytime. Anyone had this problem. Maybe it's just a cheap part and I may need to get an oem one?
Jeff
Old 11-13-2013, 07:41 AM   #11
Andy4639
Old member
Andy4639's Avatar
Did U try and loosening the screws a little? This may solve it. Just tweek them as we say.
Old 11-13-2013, 08:51 AM   #12
1972SUPERSB
Yeah I tweaked that part last night and it seems to be working now. Thanks
Jeff
