Old 11-11-2013, 11:53 PM   #1
kamikazekyle05
kamikazekyle05's Avatar
disc brake spindle
I ran into a little snag on rebuilding my front end. It a 67 c10, the spindles I'm using are a 71-72 disc brake, all the tie rods( and the center link are 71-72. The problem i ran into is the outer tie rod shank doesn't seem long enough. With it seated in the spindle, the hole for the cotter pin is just a hair below the spindle, even when torqued down. Ive mic'd the tie rod and everything seems right. Any suggestions?
kamikazekyle05 is offline   Reply With Quote
Old 11-12-2013, 05:44 PM   #2
kamikazekyle05
Re: disc brake spindle
Bump
Old 11-12-2013, 09:08 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Don't know if this is your problem but that happens when the earlier tie rods are used with the disc spindles.Maybe you got 67-70 tie rod ends?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-12-2013, 11:34 PM   #4
kamikazekyle05
I tried the old tierods and they fit loosely, but the tierods end is smaller and won't thread into the adjustment sleeve, since I'm using the 71-72 linkage. Can anyone verify the numbers on my spindles are 71-72?
Old 11-13-2013, 09:29 AM   #5
snipescastle2
snipescastle2's Avatar
Talking Re: disc brake spindle
you may have to use a "Ball Joint Reamer" southwest speed has these, the modified racers use them a lot.....
HTH,
Ben
snipescastle2 is offline   Reply With Quote
