Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-12-2013, 12:31 AM   #1
dmartin1
dmartin1's Avatar
good mild 454 piston rings?
what are some good piston rings(maker brand etc) for a mildly built 454. .030 over mini dome pistons .150 dome(i think) srp pistons.fully blanced. 049 open chamber oval ports that are getting some mild port/bowl work and bigger valves (maybe) msd ignition airgap intake and a healthy cam.
it takes 5/64 5/64 3/16 rings.
im ready to order some but would like to educate myself a hair bit more on the rings and which are better.
and a quick one..good main bearings?
this is not a 10,000$ motor so in budget would be kinda nice. thanks guys!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 11-12-2013, 01:58 PM   #2
bbcmudtruck
Re: good mild 454 piston rings?
Hastings are good. Total seal are good as well. Although some of the builders prefer not to use the gapless top rings. Either way, moly coated rings will do the trick.
bbcmudtruck is offline   Reply With Quote
Old 11-12-2013, 08:42 PM   #3
dmartin1
dmartin1's Avatar
sir thank you very much. i have used hastings in a few sbc mild builds but not anything with this sort of power(compared to them)
65 nova
And more
Old 11-12-2013, 09:12 PM   #4
dmartin1
dmartin1's Avatar
where in the world would i find hastings moly rings for the 454? its 4.280 .030 bore.
for some reason its nearly impossible for me to find? summit didnt pop up with any.
5/64 5/64 3/16 rings. AHH!
65 nova
And more
Old 11-12-2013, 09:16 PM   #5
dmartin1
dmartin1's Avatar
http://www.ebay.com/itm/Total-Seal-P...0c6544&vxp=mtr
http://www.ebay.com/itm/BBC-454-496-...722ee2&vxp=mtr
65 nova
And more
Old 11-12-2013, 11:56 PM   #6
bbcmudtruck
I guess I should have asked if you wanted to file fit your rings or just get a set for you bore and roll with it? CNC motorsports is a great company to deal with. Instead of buying them off of ebay, consider giving them a call and talk to them about what you want to do. Mahle and JE also make good rings. I always file fit my rings, but some guys just buy bore specific and have good luck with them. File fitting rings can take a little extra time, however I think the pay off is worth it.
Old 11-13-2013, 12:09 AM   #7
cableguy0
How did they balance the engine without the rings? Secondly you need to check what rings srp recommends using with their pistons. Moly rings will work fine.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-13-2013, 01:39 AM   #8
dmartin1
dmartin1's Avatar
I'm sorry for the mis clarification the engine was balanced before disassembly.I bought it from a friend.not that it matters now.
Anywho, thanks for the tips on the rings. I'll give a few company's a call and get it Rollin. I just wanted to educate myself on it before I went searching.
65 nova
And more
Old 11-18-2013, 11:23 PM   #9
Blackpony
Blackpony's Avatar
keep in mind that mahle, perfect circle, hastings, clevite are all the same company. If you buy a set of say hastings rings, they will be the exact same as a set of mahle just in a different box.
as for the bearings, a clevite h bearing should do the trick.
Blackpony is offline   Reply With Quote
