Anybody know alignment specs?
Posted in the 4x4 section but didn't get a response. Anybody know the camber/caster degrees and the toe specs for a 1960 K20? The front end is original! I believe it's a Dana 44 closed knuckle with manual steering. Any help is much appreciated!
Re: Anybody know alignment specs?
I'm thinking probably neg .5 to 0-camber, .5 - 1.5 + caster, and 1/16 to maybe 1/8 toe from what I've read but haven't seen much on old stock 4x4's and don't trust the guys at the alignment shop to know or find the specs for my truck. Any help is appreciated and Thanks in advance.
caster +1 +- 1/2
camber +1/2 +-1/2 toe + (in) 1/16 to 3/16 1/8 preferred always have the left side slightly more + camber than the right (about 1/4 degree) |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Caster 3 degrees
Camber 1 degree 30 minutes Toe-in Max.0 degrees-21min. Min. 0 deg-6min each wheel King pin inclination 7-1/2 deg. Turning angle 29 deg + 1 deg -0 deg. 1963 SHOP MANUAL
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Thanks guys! That really helps a lot!!!
