Old 11-12-2013, 11:06 AM   #1
AirSpeed
AirSpeed's Avatar
Steering locked up for a second
I was driving straight down the highway and tried to make a slight steering adjustment and the wheel felt locked up, I turned slightly harder and it popped loose and was normal again. This has happened twice but I can't find anything. Any ideas what to look for?
AirSpeed is offline   Reply With Quote
Old 11-12-2013, 11:09 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Steering locked up for a second
Just my thought but it sounds like something in the steering box.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-12-2013, 11:28 AM   #3
cdowns
cdowns's Avatar
there is an "adjustment" screw on top of the box that alot of guys use incorrectly as a cure all to steering problems// that has more than likly been messed with and causing the problem// the cure is a new box
Old 11-12-2013, 11:47 AM   #4
Sammy
Have had that happen before at slow speeds before. That is the reason I always now replace the gear box. I suspected before the worm gear some how internally failed. I suspected my case was from sitting for years or maybe under water from a flood or something at one time. In my case there was a few hints before hand. Some indications of a occasional binding felt in a turn but never constant. Thought it was at first a pump acting up. I was only pulling into a parking place at a slow speed when it locked up not turning what so ever in a hard left turn. Since then replacing any projects with rebuilt ones after my experience. Never know how many miles is on a used box before they are shot or how many years they sat exposed internally to the elements or even water conditions. If it happens once you will be awoken to a steering box failure.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
