Removing 235 --any tips?
Will be removing my 235 in the next few days, and wanted to get some tips/opinions/feedback on pulling motor.
Also, which bolt holes are folks using to attach chain/hoist? I'm looking at the one side where the intake bolts to the head, and using those bolt holes...is there a better alternative? Thanks much! Ralf |
Re: Removing 235 --any tips?
There is a ton of info out there on this.
Use a leveling bar, and DON'T use any outside head or manifold bolt holes. Pick a hole away from the edges, these things are heavy(600+ lbs.), you don't want to rip a corner out. |
#3 | |
Have whole front clip removed, everything disconnected going to motor from rest of truck...just need input on where to attach the chain to lift ![]() Thanks for the tip on not using a corner/outside hole. Glad I asked, because that's what I had planned to do. Thank you for this advice. |
OK, am going with this...in case anyone needs it for future use:
http://chevy.oldcarmanualproject.com...4ctsm0621.html |
#5 | |
