Old 11-12-2013, 01:43 PM   #1
TIMAR
98 k1500 350 vortec into 87 k10?
Boy hit a deer Sat night with the 98. Neighbor has the twin to it for sale so I am going to buy it. Have a 87 k10 that has an oil burnin weak-ass engine it. Would the swap be hard? (Vortec into the 87)? Would the whole drive train swap in? Motor, auto-trans, and transfer case?. Needs rear differential work too. Same ratio. Would they swap?
TIMAR is offline   Reply With Quote
Old 11-12-2013, 05:16 PM   #2
4x4k30
4x4k30's Avatar
Re: 98 k1500 350 vortec into 87 k10?
yes you can swap the 98 engine in and transmisson in the 87 but you will need a transfer case and t case adapter cause the 87 has the front diff on the right side to where the 98 tcase is on the left side. you will need to install a higher presssure fuel pump in your tank .everything else will swap in pretty easy check some forums youm will see where many folks have done this swap.the 98 rearend can be used in your 87 too with minor fab work.
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 11-12-2013, 07:31 PM   #3
TIMAR
Thanx . I was wondering about the fuel pressure
Old 11-12-2013, 08:45 PM   #4
TheBlueBomber
TheBlueBomber's Avatar
Im actually in the market for a vortec 350 im going to convert to a carbureted motor for my k10. I have one now in my z71 and man is it fun for a stock motor.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
