Old 11-12-2013, 06:47 PM   #1
ChevyGearHeads
3 Speed to TH350 Speedometer cable?
I have a '68 C10 LWB and swapped from a 3 speed on the column to a 350 turbo and am wondering which speedometer cable gear to use? Any information is greatly appreciated
ChevyGearHeads is offline   Reply With Quote
Old 11-12-2013, 07:00 PM   #2
midniteblues
midniteblues's Avatar
Re: 3 Speed to TH350 Speedometer cable?
pretty you can use your original speedo cable. but you might have too rout it a lil differnt.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-13-2013, 08:16 AM   #3
ChevyGearHeads
Oh, I mean't the driven gear, the different colored plastic ones?
Old 11-13-2013, 10:56 AM   #4
old Chevy guy
old Chevy guy's Avatar
If you mean the one on the end of the cable drive, I should think the same one that came out of your 3 speed should work for the 350. Your issue is the one that drives that gear that's on the output shaft inside the tail. Not sure that one will interchange with the 350. You need to hook it up and check your odometer on a measured mile and see if it comes out even . If its 10/10ths to a mile the speedometer should be accurate. If not then you have to change gears. I'm certain there is a table for that somewhere, its come up before.
old Chevy guy is offline   Reply With Quote
Old 11-13-2013, 11:10 AM   #5
geezer#99
geezer#99's Avatar
Maybe this one.
http://www.transmissioncenter.net/sp...____va.htm#350
Old 11-13-2013, 01:47 PM   #6
68gmsee
Active Member
68gmsee's Avatar
I used a GPS on my truck to check my actual speed. I wrote down the actual speed compared to what the speedometer was showing at different speeds up to 70 mph. This will give an idea of which gear to use. I only had to change the driven gear but I've heard that it's easy to change both on a TH350.
Found this: http://www.chevytalk.org/fusionbb/sh...hp?tid/165567/
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
speedometer cable
