11-12-2013, 10:37 PM | #1 |
Best place to get 12v power to hei on a 68 327?
How did you guys do it?
11-13-2013, 09:04 AM | #2 |
Java Mechanic
Re: Best place to get 12v power to hei on a 68 327?
I'm tapped off the "ign"
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
11-13-2013, 09:52 AM | #3 |
I removed the cloth covered resistance wire running from the outside fuse box to the old points distributor and replaced with regular wire. This was on a 68.
There is a nice write up on here about converting to hei and it shows you exactly how to do it, all the way down to popping the terminal connector out of the fuse box. Looks stock when done.
68 Chevy Short Stepside 250, 3 on tree |
11-13-2013, 09:58 AM | #4 |
Here's the thread . Its for a six cylinder but it shouldn't be any different with a 327.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
11-13-2013, 05:45 PM | #5 |
I find the pink wire on back of the ign. switch. I scrap some insulation off of it & solder a 12 gauge wire to it. Run it through the fire wall & hook the connector to it for the HEI unit.
11-14-2013, 06:20 AM | #6 |
Thanks guys!
