11-13-2013, 12:29 AM | #1 |
1971 C20 Static drop.
Looking to drop my 71 c20 but i'm having a hard time finding the parts i need.. I DON'T WANT TO DO A C10 AXLE SWAP! I want to have a dropped 3/4 ton long bed for a bike hauler.
So far I found These for the spindles. Springs Can't find a flip kit for the rear! also don't know how legit the drop spindles or the springs are... ANY help would be rad! |
11-13-2013, 08:42 AM | #2 |
67-72 parts collector,…
Re: 1971 C20 Static drop.
Performance Online also carries C20 drop parts for the 67-72 trucks.
11-13-2013, 09:53 PM | #3 |
Are the rear leafs 2.25 or 2.5"?
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
11-13-2013, 10:47 PM | #4 |
POL sells the front spindles and cut one (or one and a half coils). 14bolt? They dont make flip kits for that. You need to buy new perches and weld them on.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-10-2014, 02:35 PM | #5 |
Hate to bring up an old post but was wondering if spindles from a 1987 c3500 would work on a 1971 C20 suburban?
06-10-2014, 09:09 PM | #6 |
I have a set of drop spindles for a 72 3/4 ton that I'm not using
06-10-2014, 09:52 PM | #7 |
06-10-2014, 10:53 PM | #8 |
They are from early classics. It's the c20 to c10 conversion drop spindle. 2-1/2 drop. Check out there site but I believe it runs standard c10 brakes. Bought my truck with them on and when I went to swap to tubular control arms that's when I found out I have all 3/4 ton suspension. I ended up buying drop 1/2 ton spindles to run the tubular arms.
100 bucks plus the ride and there yours The only thing I'm not sure is the brakes. I have 6 lug so that's why I thought I had 1/2 ton stuff up there. Not sure if you can run the 3/4 ton brakes |
06-11-2014, 11:53 AM | #9 |
06-11-2014, 11:59 AM | #10 | |
06-11-2014, 12:08 PM | #11 |
I'm sure the C20 to C10 conversion uses C10 discs, I'm sure I got mine on eBay for around $200.
06-11-2014, 12:34 PM | #12 |
Ratty65, for some reason my 71 had newer stock spindles on it so when I installed the 71 c20 drop spindles the rotors fit bit the calipers wouldn't fit. So if you change to the newer c20 drop spindles you have to change all the front brake parts too.
06-11-2014, 12:40 PM | #13 |
Yeak I think Ill pass and pony up the extra cash when availabel and get the ones I need. BTW chevy2tom nice truck. Dont see too many C20's
06-11-2014, 12:46 PM | #14 |
Ther eis a nice cruise in in downtown Mundelein today and weather permitting I'll be ther ewith the 72 suburban. My wife may bring her 1968 suburban as well.
06-11-2014, 01:25 PM | #15 |
Thanks, is your 72 static or bagged? It looks low. I've got to do a cam change on mine(bad lobe) but hope to be back on the road by the end of the month. What's the location for the cruise night & is it every week?
06-11-2014, 01:28 PM | #16 | |
http://www.parkonpark.org/ |
06-11-2014, 02:19 PM | #17 |
Maybe I'll come up tonight to check out your suburban. Yep not to many C20s especially lowered ones. I want to bag & notch mine this summer along with an overdrive trans.
06-11-2014, 04:21 PM | #18 |
Ok so just got word that there will be a special appearance of the DAllas Cowboy chearleaders so may be a nice turnout.
06-11-2014, 05:00 PM | #19 |
Yep, leave the wife @ home lol.
