Old 11-13-2013, 10:03 AM   #1
aotte1
1965 Power Steering C10 to K10??
1965 chevy K10 long bed 4x4. Will power steering from a 1965 C10 fit the K10?
Is it direct bolt up, or are mods, or additional parts needed?
Is better to use the newer style power steering from a late 1966 or newer truck?
Les
aotte1 is offline   Reply With Quote
Old 11-13-2013, 10:26 AM   #2
MitchFloyd
MitchFloyd's Avatar
Re: 1965 Power Steering C10 to K10??
Les
No a C10 pwr steering gear box will not directly bolt up to a K10. Different model was used on the K10's.
Best bet is to find a pwr steering gear box of a 1974-84 model truck and modify.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 11-13-2013, 01:26 PM   #3
aotte1
Mitch,
I am new to these trucks and;
Just to clarify:
I was thinking the 65' power steering is a ram rod set-up, vs the later units that had the assist in the steering box, starting around late 66'. So you are saying a two wheel drive unit will not work on a four wheel drive steering linkage e.g. The 65' four wheel drive power steering is different. And that later units are easier to modify to work.
Les
Old 11-13-2013, 01:52 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
You have a valid question.
At first I thought you were asking about the power steering upgrade as most do with the 73-87 box.
But you actually have Factory Power Assist Steering.
http://67-72chevytrucks.com/vboard/s...d.php?t=561381
So in your case, the actual steering box may be the same.
Good question.
Hopefully someone knows the answer.
66 C20 Service Truck:
Old 11-13-2013, 02:05 PM   #5
MitchFloyd
MitchFloyd's Avatar
No, Your question was if it was a direct bolt on. And it's not, it'll take modifications due to the steering gear box mount. The K model steering boxes are not the same as the C models. Also the pitman arms are different, so connecting to your linkage will be different angles. So if your gonna change, it's best to just go with a newer model setup. Get the complete setup from a newer model donor for less hassels, finding / modifing parts and pieces to fit.
Also, trying to find 64-66 K10 power steering will be difficult as well as expensive, if you can find any worth rebuilding.
One other suggestion would be to PM CaptainFab. I know he was working on some pre-fabbed K10 power steering mounts. He should be able to help get a parts list together for you.
'62 Chevy K10
Old 11-13-2013, 02:19 PM   #6
LostMy65
LostMy65's Avatar
Thanks Mitch.
Old 11-14-2013, 01:30 AM   #7
Captainfab
60-66 Nut
The factory power assist steering used on the '60-'67 'C' series trucks will not work on a 'K' series truck. Totally different steering assembly.
The '68-'87 'C' series integral power steering boxes are the same as the '68-'87 'K' series steering boxes except for the sector shaft (output shaft). The casting itself and most of the internals are the same and are interchangeable. With that said, if you want to add power steering to your '65 K10, you will need a power steering box from a '68-'87 'K' series truck, Suburban or Blazer. You will also need an adapter plate to mount it to the frame, plus a power steering pump, brackets, pulleys and hoses for the particular engine in your truck.
Old 11-14-2013, 07:42 AM   #8
aotte1
Thanks for all your assistance in this quest!!
Les
Old 11-14-2013, 10:15 AM   #9
MitchFloyd
MitchFloyd's Avatar
Captain,
You are da man! Thanks for sharing you expertise and knowledge. I sure do like learning the easy way from all you guys that actually know their stuff and what really works and doesn't pertaining to these particular year models. It makes it a heck of a lot easier (and major cost savings) for people like me that just wanna learn the ins & outs of these trucks.
I can tell you that you guys and this forum have saved me several times at the parts store & a few hours hammering out issues!
So there's my thanksgiving! LOL
'62 Chevy K10
Old 11-14-2013, 01:14 PM   #10
61K10
61K10's Avatar
I put p/s on my k61 using Captain's plate. it's a little different than a c-10 install. you also need to shorten the steering arm 1 3/4" and i used a skyjacker dropped pitman arm. probably get buy without it, just makes it a little more level.
some info in the facts section--can post pics if anybody is interested, and some part #
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-14-2013, 01:40 PM   #11
aotte1
61K10,
Yes would like to see your set up.
Les
Old 11-14-2013, 03:42 PM   #12
61K10
61K10's Avatar
Les---go to the facs section on the 60-66 main page--scroll down to power steering and find 4x4 power steering---has a bunch of info + mine and part # for the drag link.
kimble
1961 chevy K10
Old 11-14-2013, 07:57 PM   #13
60-66
60-66's Avatar
Question, according to the Chevrolet parts books 4x4 factory slave cylinder power steering was available in 1967. Ive bought a few NOS parts over the years for one of these setups but am still missing some main parts. Anyone ever seen or have a complete setup ? Years ago on EBay there was a 1966 GMC 4x4 with slave cylinder PS... just to keep ya thinkin
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-16-2013, 10:42 AM   #14
aotte1
61K10
Thanks for the reference to FAQ section on power assist/ power steering. After reading that section got lost for the rest of yesterday reading all the other great information/knowledge their.
Les
