Old 11-13-2013, 11:03 AM   #1
wjjeeper
wjjeeper's Avatar
Confirming wheel stud specs
Used the search function and can't seem to find my answer to these questions.
1- Want to confirm that 65 c10 rear wheels studs should be 7/16 - 20 thread?
2- What is the stock length of the rear wheel studs?
3- What is the correct knurl diameter? .480"?
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 11-13-2013, 04:40 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Confirming wheel stud specs
According to www.oreillyauto.com following are the specs for the front and rear lug studs for a 65 C10 with both front and rear coil springs. Suspensions with rear leaf springs use a different stud on the rear axle.
Dorman® AutoGrade™ - Wheel Lug Stud
Part Number: 610-186
Line: DOR
• 1 year limited warranty
• UPC: 19495608868
• Wheel Bolt
• Multiple Applications
• Rear
1. - Rear Coil Spring Suspension
• Front
• Front
1. - Rear Leaf Spring Suspension
• 7/16-20 Serrated Wheel Stud - .472 In. Knurl, 1-1/2 In. Length
• Sold Individually
• Thread Size: 7/16-20 Inch
• Knurl Diameter (In): 0.472 Inch
• Length (In): 1-1/2 Inch
• Shoulder Length (In): 0.34375 Inch
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-13-2013, 06:42 PM   #3
wjjeeper
wjjeeper's Avatar
Thank you!
