11-13-2013, 12:54 PM | #1 |
Post your aluminum radiator set up!
Want to see some ideas on different set ups using stock or other brackets.Custom plastic/aluminum shrouds and electric single /dual set up or engine fan driven .
11-13-2013, 12:56 PM | #2 |
Re: Post your aluminum radiator set up!
Engine fan driven set up!!!!
11-13-2013, 12:59 PM | #3 |
Anyone
11-13-2013, 02:30 PM | #4 |
BAD BOW-Silverado XST
I run dual LS Camaro fans on my 454 two row radiator. It's busted right now. I hope to buy a new one this weekend or in two weeks. The stock shroud covers most of the radiator. When I install the new radiator, I'll use an extra panel and cover the bottom. It needs to pull more air through the radiator for A/C cooling. I'm also closing the gap between the radiator and condensor.
11-13-2013, 03:25 PM | #5 |
Cool I read that you run 308 gears. What is your opinion on 373s over the stock 273?
11-13-2013, 03:37 PM | #6 |
Welcome to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574370 |
11-13-2013, 05:01 PM | #7 | |
I onced towed the same trailer with both my Jimmy (4.3L/3.42 gears) and my truck (5.7L/3.08 gears). The Jimmy towed way better with a smaller engine and larger tires. Gears are great. If you plan to run at minimum a 28" tire or larger with a 700R4, 3.73 gears are ideal. |
11-13-2013, 08:13 PM | #8 |
11-13-2013, 09:57 PM | #9 | |
