Old 11-13-2013, 01:26 PM   #1
Houston Ben
Houston Ben's Avatar
Temp Sensor
Hi all,
I ordered part numbers ATM-2259 and ATM-2277 from Summit and have installed them. The gauge started to read the temp but then goes kinda haywire and jumps around a bit. Also, when I turn the truck off it sticks in place untill I turn the car on again. Did I use a wrong part or something?
Thanks,
Ben
Houston Ben is offline   Reply With Quote
Old 11-13-2013, 08:04 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Temp Sensor
...for what gauge?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-13-2013, 10:22 PM   #3
Houston Ben
Re: Temp Sensor
Stock 86 gauge.
Old 11-13-2013, 11:53 PM   #4
crazy longhorn
Fabricate till you "puke"
Re: Temp Sensor
Temp moving around, could be an air bubble in the system yet? Not sure on the guage stick....could be in the guage, or elect system. You should have had only 1 wire to hook up, (to the sender). Is the end crimped or soldered tight? I cant say how those pcs work, as far as proper read on the stock guage, but used em on mine with the Autometer short sweep guage. No issues, Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-14-2013, 12:28 AM   #5
Houston Ben
Re: Temp Sensor
Is there a certain way to fill the engine with coolant besides through the radiator to keep air bubbles out?
Old 11-14-2013, 12:56 AM   #6
crazy longhorn
Re: Temp Sensor
It wont get em all out.....but I filled the block, through the top rad hose pipe on the water pump. After that, install the top hose, & fill the radiator She still burped up a few bubbles, running with the cap off. Do you have the steam line run to the top of the waterpump, or into the top hose (either should work) ? longhorn
Old 11-14-2013, 02:33 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Temp Sensor
Besides what was mentioned; the 2259 is listed as being for "short sweep gauges 1995 and newer". I think if you were doing it for a later model gauge, or adding an aftermarket gauge it would be correct. I think in this instance its resistance sweep isn't listed, but I could imagine it isn't the same as stock.
Why can't you use the stock temp sensor with one of the other adapters they, or one of the other retailers sells? Summit, Autometer and S+P all have a variety of them.
Old 11-14-2013, 02:46 AM   #8
crazy longhorn
Re: Temp Sensor
From the read that I got...(also looking at the sender), the 2259 is a short sender, the sender that came with the guage would not fit through the hole on the 2277 adaptor, on the LS head? I would also guess , that the sweep is off (stock vs aftermarket)? Longhorn
Old 11-17-2013, 08:03 PM   #9
Houston Ben
Re: Temp Sensor
now that the thing is running, the temp gauge sees to be holding without any problems now. Didn't get to play with the truck this weekend :-(
