What temp thermostat
So I'm changing my thermostat some people tell me to 180 some people say 195 I don't know which one I'm at the store now they have both in stock. Someone please chime in thanks
Re: What temp thermostat
I prefer a 180. But up north your heat will be better with a 195 and itll take a little bit for the engine to warm up.
1979 ![]() 1996 Silverado x-cab "the daily" |
Great thanks that's what I'm going with..
I run a 180.. In Ct. too..No problem with heat, and I don't have a blower..lol
In olden days, sometimes people would change the thermostat with the change of the seasons. I use 160 degree T stat because I am more concerned with overheating in the desert, and it does that job well, but I have all new AC Delco water pump, fan clutch, etc.
Master Hater
remember a t stat controls how long the water sits in the radiator , and the block disapaiting and absorbing heat, if you go to cold, it will not give the water in the rad time to cool and won't allow the water in the engine time to absorb the heat out of the block. 195 should be fine, its not a performance engine and warmer engines are more efficient.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
