Old 11-13-2013, 09:04 PM   #1
jbassC10
Alright guys, time to drop the C10!..?
Question: Will a 4/6 drop work without me having to put a half "C" notch in the frame? I'm rolling on 20's with front 275x45x20 Rear 295x45x20....
Still looking for a good price on a 4/6 drop to..?..
Online sites to check out??
~Thanks!
jbassC10 is offline   Reply With Quote
Old 11-13-2013, 09:17 PM   #2
jbassC10
Re: Alright guys, time to drop the C10!..?
Will Only Springs Work?
Site below is a 4/6 springs only??
http://www.summitracing.com/parts/hs...del/c10-pickup
Old 11-18-2013, 09:09 AM   #3
MalibuVLX
I would C notch for a 6" in the rear. I don't like springs only because it is very difficult to get the front aligned. W/ drop spindles you can still get factory specs w/out re-alignment parts up front. Tires wear better and ride is similar to stock. We did 2.5 drop spindles and cut one coil and truck actually rides better now. Names- Porterbuilt and McGaughy's are ones I have used. Don't necessariy go with the cheapest. A named brand will make your installation go a lot smoother.
P.S. Looks like you have been on here a while. Search and you will get more info that you can stand to read. Good luck
MalibuVLX is offline   Reply With Quote
Old 11-18-2013, 09:18 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Definitely don't go 4 with springs in front.6 in rear is a crap shoot on the c-notch.Some claim you have to,others claim not.1 in springs and drop spindles front with 5 in in rear.Keep in mind that you will not get 4-6 even if you use 4 drop springs and 6 drop springs.Your truck is 40 years old and is probably lower than stock from sagging springs etc.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-18-2013, 11:31 AM   #5
ksshane
ksshane's Avatar
More than likely you will have to notch it.
I highly recommend spindles and springs in the front. I know my aliegnment shop is having a heck of time getting mine right and I did spindles and 3" springs.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 11-20-2013, 02:03 PM   #6
jbassC10
HEy!
Thanks guys!
Man this is a for deal just simply dropping it. lol
And you right the truck is old so the 4/6 doesn't acutally do what it sounds like.
Finanically is the MAIN one thing I'm keeping in mind as far as Drop spindles etc...notch :-\
Again, if you have any online sites like with a good price I could handle on dropping I would thank you for!
I could handle $500 or less
Old 11-20-2013, 02:29 PM   #7
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
You won't be able to lower it properly for $500 (maybe getting used parts)
You can get by w/o the rear notch
front:
springs spindles and shocks
Rear:
springs
shock relocators
shocks
track bar
I would check with cpp and see what they can do for a 4/6 with a forum member discount. If you have a 70 and earlier you will want to swap out the front drums and that adds a decent chunk of $$.
http://www.classicperform.com/Store/...ck/6370BDK.htm
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 11-20-2013, 02:46 PM   #8
smoked68
smoked68's Avatar
We did drop srings first, rode like a wagon. Did the drop spindles and spring in back now, rides like a 45 yr old cadillac now. Reeeal good. Did do the C-notch?? had bags for a brief time. No more.
IMO save and do it right the first time, I got the drops from Brothers I think, gotta get drop shocks too so save up and do it right the first time, youll actually save money unlike me...
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 11-20-2013, 03:57 PM   #9
long'n low
long'n low's Avatar
2.5" spindles and 1,1.5 or 2 coils off of the front,
5" plus drop block or 6" drop springs out back.
Thats my suggestion.
Or
PB stage 1 with schrader valves then you can pick your ride hight and can get an air management system later.
long'n low is offline   Reply With Quote
Old 11-20-2013, 06:07 PM   #10
big_al_71
big_al_71's Avatar
4/6 complete drop kit from early classics.
No cnotch needed. I had that kit in my truck for four years and I believe only once it bottomed out. truck rode pretty darn good now my truck is bagged and it drives 100% better than it did with the ECE kit.
this is real world experience
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-21-2013, 02:35 PM   #11
jbassC10
Thanks man!! Today is the shopping day so I'll check it out!!
