To drive or not to drive
What are everyone's thoughts on driving my truck to the muffler shop approximately 30 miles away without the back pressure of the exhaust?
Re: To drive or not to drive
That is what I am going to do, but it is only 8 miles!
I do have some head pipes, or down piles from the exhaust manifolds and the o2 sensors and about 3 feet of straight piles. It may be too noisy we will see
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
besides the noise... i dont understand the concern.... also make sure there is nothing flamable that the exhaust gases could start on fire
Ed will be known as the Tiger Woods of the integration business |
just baby it and you will be fine. I drove my truck about 45 miles to a muffler shop open manifolds without issue
Cool, thanks for the replies guys! Just didn't know if it would hurt the engine or not.
meowMEOWmeowMEOW
As long as you have headers, you'll be ok. If your running a radical setup, the engine will give you some fight since the 02's won't be in the exhaust path....and you'll be loud as hell and getting about 8mpg. 30 miles is longer than I would push it with that.
Honestly, in general 30 miles is farther than I'd go with anything "half way" on my truck. Besides just whether or not you CAN, should you? I'd end up with a ticket before I even got there with open headers.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
............. O K, I will add some 45* baloney sliced tips !
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I used a local guy with a trailer he drives the truck on and it puts the truck up in the air like a lift, he put the exhaust on and then drove it off. honestly scared the h311 out of me though!
I wish I would have gotten some pictures...
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Do you mean the trailer has a 4 post lift mounted to it and sitting on 4 tires and a hitch?
#10 | |
Old member
![]() Quote:
I would have a ticket before I got out of sight of the house with my luck! ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#11 | |
meowMEOWmeowMEOW
It wasn't as nice as ^^^^ but it served its purpose and it wasn't that bad, i am very particular with my truck and he was used to driving things on it...just made me nervous
