'67 C10 accelerator pedal rod firewall support???
Greetings all, I'm a noob here. Recently got my '67 C10 stepside and I'm in love.
It seems like there are a lot of sources to buy ALMOST any reproduction part you need. However, I've been searching high and low for an accelerator pedal rod firewall support (circled in the attached drawing) to no avail. Could someone kindly point me toward a possible source for these source for these? I've looked at Ecklers, LMC, Classic Industries, and various other places after some extensive Google searches. Can't figure out if no one is making them, or if I just haven't hit the right search term. Thanks for your help. Last edited by FreeRangeChicken; 11-14-2013 at 12:35 AM. |
Re: '67 C10 accelerator pedal rod firewall support???
I don't think anybody makes them. Best bet is to search the parts board on here and look for somebody parting out a truck.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
![]() Join Date: Mar 2012
could you upgrade to a 72 style? i think those are available online
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Thanks for the tips, guys. I'll check out the parts forum and the other links.
BigMac73, I'm not sure about changing over. It's something I've thought about, but I need to research some more. I think on the later version the whole rod is in the cab and the cable (or carb rod) penetrates the firewall, where on the earlier ones the pedal rod penetrates the firewall and is 1/2 in / 1/2 out. Need to look at that some more. Don't think it would be just a bolt-on swap.
Dave L. 1967 Chevy C10 SWB Stepside, L6 250 1967 Chevy C10 Fleetside, LS2 6.0L 1972 Chevy C10 LWB Fleetside, 350 |
#6 | |
![]() Join Date: Feb 2002
I converted my '68 C/10 Stepside to an aftermarket/'72 GM set-up. It works great, and I'm happy with the result.
My needs were special: I have a 4-barrel [500 CFM ] Edelbrock carb on an Offy intake on a built 292 L6. The stock linkage was scrapped long ago, and the improvised push-pull bellcrank around a 90* angle to the carb's throttle lever had bad tendencies, like jamming, losing cotter pins, freezing up -- always at the worst times. Also I never got WOT out of my old carb. a 390 CFM Holley. Since I put the cable on I have had no throttle issues. Maybe the only comment is that at the stoplight, I have to take my foot completely off the gas pedal now, as just light foot pressure causes a 100-200 RPM jump over a 700 RPM idle.
I bought a complete 72 pedal assembly off of a board member on here as well as the conversion kit. If you look in the classifieds section, hes still making and selling the kits. They are very nice and easy to do. The only other thing you will need is a throttle cable. Or if you just want to stick with the rod assembly, go through the classifieds on here and there is always someone parting out trucks in there.
Found a couple of candidates over in the parts board. Thanks for the input.
I had to get one from a local junkyard. No one makes them sadly.
#11 | |
![]() Join Date: May 2010
http://67-72chevytrucks.com/vboard/s...d.php?t=604362 |
#12 | |
#13 |
I know this is an old thread but I am also looking for the same piece. Anyone know of anywhere to get one currently?
#14 |
![]() Join Date: Sep 2007
on the parts board theres a guy parting a 69, that will have the pedal assy youre looking for
1967custom |
#15 |
I made up a hybrid pf '72GM/Lokar. GM parts inside the cab and Lokar in the engine bay,
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-22-2018 at 02:56 AM. |
#16 |
Check the parts board.
#17 |
Hunting accelerator firewall bracket for a 69 c10 any help would be greatly appreciated thanks
#18 |
Old member
I just took my 68 pedal assembly out and put my old 71 assembly in it. I used the lower original mounting hole as a good spot and drilled the other two holes. Went to O-Riellys and bought the Mr Gasket generic throttle cable setup. Had to drill a new hole for the cable but so far it seems like it will work just fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#19 |
Thanks I'd like to get original if possible I'm still looking thanks
#20 | |
#21 | |
![]() Join Date: Apr 2016
#22 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-11-2020 at 09:53 PM. |
#23 |
Post Whore
![]() Join Date: Feb 2016
I believe that the 60-66 pedal is the same as the 67's.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#24 |
#25 |
No clue of prior years, but MY '67-'68 pedals pivot on a pair of stud-ball ends that are screwed into the floor.
