Old 11-14-2013, 10:42 AM   #1
aotte1
1965 K10 Optional Wider Wheels?
Was their an option for wider wheels on the 1965, K10s. If so what dimensions were they. Again I am learning this model, doing a project with my grandson. We are just starting.
Les
aotte1 is offline   Reply With Quote
Old 11-14-2013, 06:11 PM   #2
yelmer
Re: 1965 K10 Optional Wider Wheels?
check with 60 66 he has wider factory tire on his 66
yelmer is offline   Reply With Quote
Old 11-14-2013, 06:20 PM   #3
RANDY COX
RANDY COX's Avatar
Not sure What yr but my 72 Blazer had 8" wide wheels on it.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-14-2013, 07:50 PM   #4
60-66
60-66's Avatar
According to the 1965 Chevy truck Data Book, No , not from the factory. Widest available were 5 1/2 inch rims. But Special order, which would have been tricky through your dealer, things could be done. My 66 K20 was able to get the 16.5X8 wheels and is well documented. These are 8 lug rims though. I have a 1963 GMC 4x4 that I put factory Chevy 15x8 rims on. But I believe they are later 1973 on up rims. Heres a few pictures of trucks mentioned.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-16-2013, 09:49 PM   #5
aotte1
Thanks for the information. 60-66 and Randy thanks for the suggestion on stock looking wider wheels.
The 1965 Chevy truck model brochure shows a dark colored 4x4 model that appears to have wider wheels/tires. I guess the ad guys can take some liberty with the truckers under these brochures. Do you think they look wider ?
60-66 do the 8" wheels fit good and if you don't mind what size tires are you using.
Les
Old 11-16-2013, 11:35 PM   #6
MusicMan70
MusicMan70's Avatar
Those are just two-too awesome trucks 60-66!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-17-2013, 01:04 AM   #7
A.T. RockDriller
A.T. RockDriller's Avatar
No problems with OE suspension.
They're 36" 12.50x16's on 9" center fire aftermarket steel rims.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 11-17-2013, 07:42 AM   #8
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
The 15 x 8 6 lug could also be found on military vehicles 73 up.
Old 11-17-2013, 10:29 AM   #9
aotte1
Are the 1973, and up 15x8 6 lug factory wheels pretty much standard back spacing. Therefor any 15x8 non-rally (appearance) wheel will work on 64-66 4x4 K10.
I would use a narrower tire for this rim size to put less stress on steering components and frame where steering box mounts.
Les
Old 11-17-2013, 10:45 AM   #10
aerotruk63
aerotruk63's Avatar
yes standard back spacing.
Old 11-17-2013, 12:51 PM   #11
MusicMan70
MusicMan70's Avatar
Not mine/not affiliated and from the CL...do three nubs mean drum brakes only?
http://inlandempire.craigslist.org/pts/4177332605.html
MusicMan70
1961 GMC Suburban
Old 11-17-2013, 01:49 PM   #12
60-66
60-66's Avatar
I looked at the one 4x4 brochure I have with the yellow stepside on the front and your right, on page two it shows a K20 with wider looking tires but the picture is dark and hard to make out. The tires on my 63 GMC are 31X10.5 x 15 .Tires fit very well, just inward of the top lip of the fender.
Les
Thanks MusicMan70 !!!
Old 11-17-2013, 01:51 PM   #13
60-66
60-66's Avatar
Heres the wheels close up.
Old 11-17-2013, 05:28 PM   #14
aotte1
60-66
Thanks for the close-up pictures. Will help me purchase the correct wheels.
Your trucks sure look nice!
Les
Old 08-06-2015, 09:58 PM   #15
factorystock
factorystock's Avatar
The period wide base wheels in the 60s was the 8.25x16.5,both in 6 lug or 8 lug. This wheel could have been bought in the aftermarket or special ordered when new. These wheels were all clip type, the first bump type 8.25x16.5 was introduced in 1973.
factorystock is offline   Reply With Quote
Old 09-08-2015, 09:09 AM   #16
aotte1
Factory Stock,
Thanks for the additional information, to add to our knowledge of these trucks.
Les
