Old 11-14-2013, 01:12 PM   #1
Slowgoin
alternator bracket
Looking for an alternator bracket that bolts to the front of the ram horn exhaust manifold, on the drivers side. Anyone know what will fit ? I've seen one for a '66vette that appears it would fit, but not sure if the bolt configuration was the same on all the exhaust manifolds.
Slowgoin is offline   Reply With Quote
Old 11-15-2013, 01:01 PM   #2
luvbowties
luvbowties's Avatar
Question Re: alternator bracket
It may help to know if you want one for front,end---or front,side...
Sam
luvbowties is offline   Reply With Quote
Old 11-15-2013, 01:21 PM   #3
Racer2172
I have a complete motor in the shop out of a 72 if youd like i can post a pic later of the setup
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 11-15-2013, 02:39 PM   #4
davepl
davepl's Avatar
If stock appearance isn't a factor, then I've done wonders with heim joints (or whatever the ball in socket things that the Nazis invented are called). They don't provide side to side stability, but work great for mounting anything perpendicular to the block/heads.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-15-2013, 04:33 PM   #5
Slowgoin
It would be for the front end of the manifold, not the side. I believe the bracket that I need has 2 bolt holes where it mounts to 2 holes in the front end of the exhaust manifold and a support bar that goes to the water pump bolt. At least that's what I think is needed. If you search images of 66 corvette alternator brackets, you'll find these, and it appears correct, provided there were not different bolt patterns on the front end of the manifold. My exhaust manifolds came off a 283 motor, unknown year.
Old 11-15-2013, 10:32 PM   #6
425HP409
425hp409
425HP409's Avatar
I believe that the bolt configuration on the front of the manifolds are the same.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 11-15-2013, 10:32 PM   #7
100%Chevy
The bracket was used in the mid-60's on most Chevy small block engines.
It is stamped steel.The support leg does go to the top wp bolt.The other end goes to the front of the manifold where the bottom is bolted to the manifold and the top is part of the gap where the alternator sets.The alt sets against the manifold and swivels here for adjustment.
The bolt pattern is the same on all of this type of exhaust manifolds.
I only have pics of it on the car-Not very visible under the alternator.
Mike.
100%Chevy is offline   Reply With Quote
