Old 11-14-2013, 11:28 PM   #1
Mike65longbed
Mike65longbed's Avatar
Newbie with 65 Long fleet..many questions.
Let me start by saying what a great community this is!
I have a 65LBFleet.. It has 255/70/15 all around and I like the size and wheels. I am going to do a disc brake conversion and stick with the 6 lug. My question is around dropping the truck a bit. How far can I go with this size tire. I don't know if I should go with a drop spindle or just the coils. Is there a performance difference on handling with drop spindles? My thought is to try and go 3" in the front and 4" in the back and keep a bit of rake. I have looked at all the pictures in the static drop thread, but not many long bed with tire size mentioned. Any advise would be appreciated.
Thanks Guys!
Mike65longbed is offline   Reply With Quote
Old 11-15-2013, 12:00 AM   #2
MusicMan70
MusicMan70's Avatar
Re: Newbie with 65 Long fleet..many questions.
Hello Mike and Welcome! I don't have the answers you seek but would like to see more pics of your truck please.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-15-2013, 01:19 AM   #3
19666Trucker
19666Trucker's Avatar
Hello mike, Jason here and wecome I live down around rural and mckellips, you should go to Dino's git down there ton info to get straight from the source. Just go look up in the az section of the board find out Dino C10 party
19666Trucker is offline   Reply With Quote
Old 11-15-2013, 11:12 PM   #4
MARTYZ
MARTYZ's Avatar
Here is a pic of mine with the same size tires you have , 2 1/2 drop spindles and rear air bags no frame knotch, second picture is before lowering was done
MARTYZ is offline   Reply With Quote
Old 11-15-2013, 11:37 PM   #5
Mike65longbed
Your before pic is the exact stance my truck has. 2 1/2 front seems perfect maybe ill go 3" in the rear. Any bumps, rubs or scrapping? Awesome looking truck!
Old 11-15-2013, 11:38 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Welcome
66 C20 Service Truck:
Old 11-16-2013, 05:33 AM   #7
pdxhall
pdxhall's Avatar
Welcome to the forum. It's good to see more longbeds. I'm going with a static drop. 2 1/2" drop spindles and 1" coils in front and 5" drop coils in the rear. I can't help you with tire size or the stance since it's down to the frame right now but I'll be happy to help with future questions if I can. Good luck.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-16-2013, 02:49 PM   #8
MARTYZ
MARTYZ's Avatar
Mike, no bumps or scraping in rear, reason I went with bags in the rear for adjustability, just add little air accordingly for load, set truck down level at shows ect, works well.
My only caution with drop spindles would be do a little research, some of them will widen the front track which can be an issue with wheel offsets, I put McGaughy spindles on mine and ran into this problem, I believe CPP spindles don't have this issue. Maybe someone with cpp spindles will comment on this.
Old 11-16-2013, 07:12 PM   #9
MikeS.
MikeS.'s Avatar
Mike, we NEED pics, it's a requirement.
BBW or small? I'm a fan of the LB with BBW.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 11-16-2013, 08:47 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Welcome and nice truck! I don't have the answers you seek either....but like said...WE NEED MORE PICTURES!!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-11-2014, 12:34 AM   #11
19666Trucker
How the the truck coming along.
