Ededlbrock carb/line/fuel pump
Each item listed is new, never fired. Only reason i'm selling is to switch to efi. They were mounted/mocked up, but no fuel ran thru. Please use pic for reference only, this is an actual pic of the items installed. Only items listed below are for sale.
Edelbrock 650 avs carb, dual feed fuel inlets, electric choke. Still have box with instruction manual. Currently retailing around $380, asking $375, which will include the $90 dual feed kit with polished billet fuel filter. Will also include liquid filled psi gauge as seen in picture, and the -6 an fuel line to the pump. Also has a performance stainless nipple added on back side for brake booster vacuum and a 700r4 tv cable geometry correction bracket, which is removable. Will not seperate these items.
Also for sale, edelbrock mechanical fuel pump, new, only installed, never fired. Asking $60 or if added to carb above, $50. Will come with the fuel pump push rod, also new.
