![]() Join Date: Nov 2013
68 cab info needed
Just picked up a 68 1/2 ton truck and looks like I will need a cab with air conditioning as mine has heavy corrosion What year cabs will work from 69-72 and are 3/4 ton cabs the same to repair my truck
Thanks for the help guys. Glad I found this site Richard |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Re: 68 cab info needed
Welcome to the site Richard.
Quick answer to your question.....Any 67 - 72 chevy or GMC truck cab will work with your truck as long as it is originally from a 1/2 to 1 ton truck. There are some front clip differences but you can learn those particulars here as well. If you intend on using your front clip, it should be a bolt and play scenario. Yes, there are some large window '67's still out there, so should you find one it will work as well. I personally like the small window and hope to convert my '69 over to a small window someday soon. Take care and post pictures!
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
