Old 11-15-2013, 03:44 PM   #1
Houston Ben
Houston Ben's Avatar
What temp do fans turn on?
I got my truck in for exhaust and got to really drive it for the first time. I only drove it for approx 6 miles and when I checked the temp with code reader it said it was at 212 degrees but the fans were not on. I am hoping the tuner didn't turn thoes off.
Houston Ben is offline   Reply With Quote
Old 11-15-2013, 05:16 PM   #2
Houston Ben
Re: What temp do fans turn on?
I'm asking because I have seen 190 degrees and 220 degrees and want to know which is correct.
Old 11-15-2013, 06:25 PM   #3
Indian113
Indian113's Avatar
I have mine set at 220 then my fans kick on and off at 190. That's the way my tuner did it . I've never had a problem in heavy traffic at 90+ degrees outside. It doesn't take long for my fans to cool off my radiator.
Indian113 is offline   Reply With Quote
Old 11-16-2013, 12:21 AM   #4
RaceAGMC
RaceAGMC's Avatar
Mine come on at 184 and off at 177. I have a 160* T-stat if that makes any difference. I see around 200 on hot days sitting still.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 11-17-2013, 08:01 PM   #5
Houston Ben
Cool, thanks for the replies guys!
Old 11-17-2013, 08:42 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
160* is really too cold to run in these engines 95% of the time. The 180* stat is about the lowest you usually go, with MANY high hp cars keeping the stock t-stat. These engines are designed to run in the 195-212* heat range for "optimal" output. The increase in technology and efficiency, and the decrease in tolerances means cars are burning hotter, making more power and using as much of the fuel as possible, minimizing unburned fuel.
Running the ls engines too cold will decrease power, and be detrimental to performance and longevity, barring a handful of circumstances in which it would be useful. In many cases, your making the engine spend more time trying to warm up and preventing it from completely doing so.
If you are switching to an ultra low stat to help with cooling problems, you need to look at upgrading your radiator and fans, or checking for some mechanical problem causing heat buildup. Things like water wetter, changing tranny coolers, and adding capacity can all help with cooling problems. Ultra low temp thermostats are a bandaid, only making you feel like the problem is solved, but actually masking the symptoms.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-18-2013, 09:57 AM   #7
dec010974
dec010974's Avatar
I agree with brew city. Most of the gm trucks such as the tahoes , suburbans Silverados operate in stock fashion, around 220 degrees Fahrenheit. LQ4s, LM7s, LQ9s use the thermal efficiency theory better than the sbc ever did. If it was mine , 205 degrees Fahrenheit would be my number. If the fans aren't operating as programmed, chec with ur tuner and check the relay wiring.
dec010974 is offline   Reply With Quote
Old 04-05-2014, 08:50 PM   #8
Houston Ben
I know, old post but just thought I would update, on stock setup my small fan turns on at 231 and turns off at 193 Fahrenheit.
Old 04-06-2014, 12:16 AM   #9
littlevictories
freaked me out for sure when my shti didnt come on till 200
littlevictories is offline   Reply With Quote
Old 04-06-2014, 10:07 AM   #10
solidaxel
solidaxel's Avatar
My 5.3 comes on at 208* and off at 194.5* with a 190* Thermostat.
The only times it will come on is with the A/C on or sitting ideling for a period of time, runs on the freeway at 199* with the A/C on and 197* off, HD 3 core rad new, electric fan(1), I hope everything stays there in a few months when it stays over 100* every day!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-06-2014, 09:01 PM   #11
crazy longhorn
Fabricate till you "puke"
205 on/ 195 off....Painless controls on a dual 14" elect fan setup (carbureted). The stat is 187, IIRC... My 02 runs 205-210 in summer weather, I plan to run the same way with the 5.3 in my 69, but don't have enough time on the swap to say how it goes...Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
