Old 11-15-2013, 06:56 PM   #1
Squareforceone
Squareforceone's Avatar
Can someone direct me to a good write of aligning sheet metal
Just what he title says i'm trying to put my front clip back together and want to get it all aligned right where do i start. Do i put the rad support on first inner fenders what? Thank you.
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 11-16-2013, 12:42 PM   #2
Squareforceone
Re: Can someone direct me to a good write of aligning sheet metal
anyone?
Old 11-16-2013, 07:25 PM   #3
rollin thunder
rollin thunder's Avatar
IMO I would say rad support on first it should give you a good basis on where the rest goes. then the inner and so on. and taking apart in reverse. as you might have seen in other photos around the sight when others put together or take part most of the time the rad support is all by its lonesome or that and inner. this is how we did my buddies 59 and got the fenders to line up correctly.
Taking the bumper off could not hurt at all either if its not already off.
or if your brave enough put it all together except hood on the ground and then put it all on the truck as one unit. i have done that before. I do not recommend it by yourself
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 11-17-2013, 12:33 AM   #4
sdewolfe
sdewolfe's Avatar
Search a phrase like "fender door hood alignment". There are many articles about it from Hot Rod, Car Craft, and others.
A lot of guys here have done it. I haven't, yet. I will on this truck sometime in the near future. I will be watching the responses to your question to see what I can learn before I get in to it. The article in the paint and body FAQ on the subject is mostly about correcting panel gaps if the door or jamb or fender line doesn't match; welding and grinding. Hopefully that won't be necessary for you or me.
Mr. Shannon DeWolfe
--I've taken to using Mr. because my name misleads folks on the WWW. I am a 61 year old fat man.
sdewolfe is offline   Reply With Quote
Old 11-17-2013, 07:44 PM   #5
ironroad9c1
Master Hater
make sure your door hinge bushings are good, then go from the doors forward.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 11-18-2013, 12:27 AM   #6
Squareforceone
the gaps were fine factory gaps and i just took the front clip off to do a motor swap.... I just want half way decent gaps.
Old 11-18-2013, 11:00 AM   #7
Keith Seymore
Keith Seymore's Avatar
I watched my guys do one truck per minute for about 7 years.
Here's how the factory does it (two guys required, one at each end):
a) Make sure your doors are fit properly. Radiator support should be sitting on the frame, bolts installed loosely so that it can flop around.
b) Place a small spacer (1/4" or as desired) at the top of the door and at the bottom of the door. Ours were magnetized and looked like a little "iron" (for ironing clothes). You could use a yard stick, or a paint stirrer, or furring strips, or whatever. This is what is going to control your fender-to-door gap.
c) Hang the fender (with fender inner already installed), hold it rearward against the spacers. Shoot the top rear vertical bolt (with factory shims in place), and the bottom rear horizontal bolt (with shims in place). You can use a big 4x4 or piece of wood to pry the bottom of the fender rearward against the spacer (we did).
d) Open the door and shoot the top rear horizontal bolt (with shims in place). Close the door and back off the vertical bolt slightly, so that the front end can slide side for side.
e) Shoot all of the front fender anchor/nose bolts to the fender inner.
f) After both fenders are on, set the hood. Scoot the front end assembly side to side to equalize the gaps between the hood and fenders. Once satisfied, tighten everything down (including tightening the rad support bolts at this time).
g) Repeat.
We used pre-taped-up shim packs to align the fenders to the door (up/down, and in/out) - whether that particular truck needed it or not. You will have the luxury of trying different shims to iterate and get the fit where you want it. Don't be surprised if it needs a little different shim pattern going back together than it had when you took it apart.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-18-2013, 11:57 AM   #8
Keith Seymore
60 jobs/hour * 8 hours/day * 285 days/year * 7 years = 957,600 trucks.
No wonder I remember!
(lol)
K
1979-1986
1986 - 2019
Old 11-19-2013, 08:14 AM   #9
Keith Seymore
Just re-reading this and should probably clarify here:
This is supposed to tell you to install and tighten the bolts at the front of the fender to the rad support. I seem to recall there are two at on the forward side of the rad support at the fender nose, and then five or so on the backside of the rad support running vertically along the fender inner sidewall.
K
1979-1986
1986 - 2019
Old 11-19-2013, 10:48 AM   #10
Desert1957
Desert1957's Avatar
Great write up once again Keith.
Desert
Desert1957 is offline   Reply With Quote
Old 12-19-2013, 04:19 AM   #11
Squareforceone
Where do the shims go i know at the top of the fender by cowl but where else might i put them?
Old 12-19-2013, 03:14 PM   #12
hlp-3
Keith's is your best bet for the squares, but the Autobody101.com forum is good too. Look in the Basics of Basics folder for body panel alignment of click the link here. http://www.autobody101.com/content/a...nel-alignment/
________________
2007 Trailblazer SS
1996 Corvette (sold)
1987 Silverado LWB (R20)
1985 Silverado SWB (C10)
1973 Nova SS
1965 Chevy C-10 SWB (sold)
hlp-3 is offline   Reply With Quote
Old 12-20-2013, 05:07 AM   #13
K20chevy
K20chevy's Avatar
Thanks for the writup. IŽll be doing that soon and this helped!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 03-27-2014, 11:47 PM   #14
Squareforceone
g) Repeat.
K
question about part c you to use a piece of wood to pry fender rearward i don't quite understand? Also i didn't count my shims when i took it apart (they fell on the ground) Where might i put shims?
Old 03-28-2014, 07:19 AM   #15
Keith Seymore
We used to pry pushing off the bottom of the tire and pushing rearward against the lowest part of the fender.
This helps make sure the fender is back against your spacer and is what sets the fender to door gap at the bottom.
Shims can go on the horizontal surface at the cowl, at the horizontal bolt (vertical surface) in the door pillar (inside the front of the door) or at the horizontal bolt at the rear of the fender. All of the rear attaching points of the fender can be shimmed.
K
1979-1986
1986 - 2019
Old 04-12-2014, 01:02 AM   #16
84chevyguyid
Just rereading this thread as I am getting ready to mount my crew cab and front end back on the frame. Is there a way to check alignment of the cab itself to the frame before I tighten the cab mounts?
84chevyguyid is offline   Reply With Quote
Old 04-12-2014, 02:31 AM   #17
SilverMiner
SilverMiner's Avatar
Great thread - invaluable information. By any chance is there an exploded diagram showing the location of all the doghouse bolts and shims?
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
